Results 1 to 9 of 9
Thread: diesel bleeding proceedure
    Beginner pro.020's Avatar
    Oct 2010
    BIRKDALE
    Hi guys, does anyone know the correct proceedure to bleed the diesel system after changing the filter? I'm having problems getting the vehicle to start.
    Feb 2011
    Shed
    45 Post(s)
    I'll look for me manual and get back to you tho Tony or one the other lads will prob get to you first. Is it TD42?
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by pro.020 View Post
    Hey mate - as growlers stated, someone will be along soon to offer assistance .. hope you get it sorted ... then you can come up to Beerburrum tomorrow for a play in the dirt!!! LOL
    You're only down the road from me mate - should catch up at some stage for a couple of coldies!!!
    Scotty
    581 Post(s)
    Hi mate, you need to hand pump the diesel through with the plunger thing.
    Unscrew the little plastic knob on the side of the plunger, pump the top part of the plunger until you get a good flow coming through then do that little plastic knob thing back up.
    I'll take a photo of my one with arrows, etc if you want?
  6. The Following User Says Thank You to AB For This Useful Post:
    Chappy (4th September 2014)
    174 Post(s)
    I changed the fuel filter on my TD42 for the first time last week. Owners handbook says to install filter & then pump until resistance (pressure) is felt - pump gets stiffer. I did this, got the vehicle started, but it only ran a short time then died. Pumped again - still wouldn't start. Pumped again, still wouldn't start. Pumped again - started & has run fine since. I think perhaps next time I'll partially fill the filter with fuel before fitting it to save on the pumping effort.
    regards
    Cuppa
    581 Post(s)
    Yep, you probably don't even need to unscrew that side thinngy like what cuppa did. I just pumped my brothers one last week when he ran out of fuel, like what cuppa Said you can feel it pressurising after 10 or so pumps.
    Feb 2011
    Shed
    45 Post(s)
    Just dug up my manual but yeah as AB says.
  10. #8
    22 Post(s)
    After pressurizing the pump on the filter you need to crack the banjo bolt where the fuel line connect to the pump iit will let the air out
    Benny
    96 GQ coil/Cab
    08 G6eT
  11. #9
    Apr 2011
    christchurch
    awesome good help guys
