26th March 2011, 06:31 PM
diesel bleeding proceedure
Hi guys, does anyone know the correct proceedure to bleed the diesel system after changing the filter? I'm having problems getting the vehicle to start.
26th March 2011 06:31 PM
26th March 2011, 07:11 PM
26th March 2011, 07:15 PM
Banned
pro.020
Hey mate - as growlers stated, someone will be along soon to offer assistance .. hope you get it sorted ... then you can come up to Beerburrum tomorrow for a play in the dirt!!! LOL
You're only down the road from me mate - should catch up at some stage for a couple of coldies!!!
Scotty
26th March 2011, 07:16 PM
Administrator
Hi mate, you need to hand pump the diesel through with the plunger thing.
Unscrew the little plastic knob on the side of the plunger, pump the top part of the plunger until you get a good flow coming through then do that little plastic knob thing back up.
I'll take a photo of my one with arrows, etc if you want?
The Following User Says Thank You to AB For This Useful Post:
Chappy (4th September 2014)
26th March 2011, 07:27 PM
Travelling Podologist
I changed the fuel filter on my TD42 for the first time last week. Owners handbook says to install filter & then pump until resistance (pressure) is felt - pump gets stiffer. I did this, got the vehicle started, but it only ran a short time then died. Pumped again - still wouldn't start. Pumped again, still wouldn't start. Pumped again - started & has run fine since. I think perhaps next time I'll partially fill the filter with fuel before fitting it to save on the pumping effort.
regards
Cuppa
A Nomadic Life (Blog)
26th March 2011, 07:30 PM
Administrator
Yep, you probably don't even need to unscrew that side thinngy like what cuppa did. I just pumped my brothers one last week when he ran out of fuel, like what cuppa Said you can feel it pressurising after 10 or so pumps.
26th March 2011, 08:18 PM
Smart like tractor
After pressurizing the pump on the filter you need to crack the banjo bolt where the fuel line connect to the pump iit will let the air out
Benny
96 GQ coil/Cab
08 G6eT
8th April 2011, 01:15 AM
