28th June 2015, 10:09 PM
#11
Patrol Guru
Thanks Newby. I'll check out 4by Fab. I've looked into the Radius one a fair bit, it gets a lot of good press, uses a $9 Filter that fits your standard Ford, so they're available everywhere, but the 2nd battery has to be moved about 80mm back towards the firewall, also means that vacuum canister or whatever it is has to be moved also.
28th June 2015 10:09 PM
28th June 2015, 10:37 PM
#12
Smart like tractor
nissannewby
4by fab do a panel style that should allow you to keep your second battery. Not 100% sure if the radius panel will allow second battery in standard location. But most do allow the second battery to be retained.
The piping from box to turbo can get a bit messy with some of those boxes.... even the fatz one
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
28th June 2015, 11:22 PM
#13
Patrol Guru
The Following 4 Users Say Thank You to Rocket55 For This Useful Post:
jff45 (29th June 2015), MudRunnerTD (29th June 2015), mudski (28th June 2015), Robo (29th June 2015)
29th June 2015, 04:48 AM
#14
threedogs
Nar didn't fit a zd30 box, it's std fit as far a I can tell.
that ebay one wont fit in to keep aux battery, abs and vac cylinders in the way.
someone else may like the look of it though.
thanks
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
29th June 2015, 09:43 AM
#15
Ben-e-boy
Only if you use to much silicon hose. Some people love that stuff lol
