Normally aspirated/non turbo ED33 motor (3.3 litre 4 cylinder as used in Civilians & Nissan Cabstar trucks).
What would a ‘resonator box’ do?
If an ‘indicator’ for the air filter what would it actually indicate? There are no wires connected to it.
I wondered if, because the air filter is mounted fairly low (behind the passenger side headlight) whethe it might be some sort of extra protection should water get sucked in, but if that were so I would expect the t connection to point down rather than being horizontal.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
I don’t think the Civilian one is a clogging indicator - it is a plain looking canister with no mechanical indicator mechanism & no wires attached to send a signal to a dash light..... unless it has some form of operation I haven’t considered? I’ve looked through the workshop manual & can find no reference to this thing.
