29th June 2015, 08:15 PM
Lexx
Hey all, so I have had the turbo rebuilt and I reinstalled same with all new gaskets and nuts, torqued to spec as per manual supplied by this magnificent site! (thanks!) Nothing was dropped in jono 6974, i made sure to be careful on the install. Bills gu, i have checked the shield and customised same for my temperature probe, so all seems ok.
robewott - perhaps its a polished bearing in the turbo, or pitted bearing, get a stethoscope and see exactly where it is coming from, use a hose with a barb end (from bunnings irrigation section, use a barb end with any kind of hose the fits) and see where exactly where the noise eminates from.
It's only there when the engine is cold. It sounds like the exhaust manifold.
29th June 2015 08:15 PM
29th June 2015, 10:27 PM
Could be a slight blow from an exhaust gasket that seals when engine warms up.
6th July 2015, 10:39 PM
apart from the the head gasket on the exhaust side, what other gaskets will i need after pulling off the manifold? Can the turbo unit be pulled to one side while the ex gasket is replaced?
31st May 2016, 08:28 PM
Hi guys, unfortunately I have been unable to reply for some time. I have sorted this issue out, it was the exhaust manifold gasket. It was THE ONLY one I didn't do when I rebuilt the turbo.... pulling it all down again and paying for new gaskets... slightly annoying.... cutting hands on heat shield... again... totally enfuriating!
Cheers all to the good advice
2004 GU ST, ZD30 DDTi.
Mods so far - EGT & Boost Gauges in Pillar Pod, NADS, upgraded inter-cooler, 2 in suspension lift, 33 in tyres, steel bullbar, spot lights.
The Following 2 Users Say Thank You to Lexx For This Useful Post:
Avo (31st May 2016), BigRAWesty (31st May 2016)
1st June 2016, 07:49 AM
Was looking at the Necro thread digging. Nearly a year... LOL
At least you sorted it.
There is no legal cure for STUPID!
1st June 2016, 08:01 AM
Lexx
Hopefully you modified the heat shield for future removal etc..
I found mine comes off much easier with actuator taken off..
But issue found. Nice one.
1st June 2016, 11:02 AM
#17
BIGGUWESTY - Stop reminding me of things AFTER I have done them! Although, I found I can get the shield on if I am patient and gentle, which isn't often lol.
LOSTBENJI - I'm like a good woman, never forget and pounce years after the fact!
The Following User Says Thank You to Lexx For This Useful Post:
BigRAWesty (1st June 2016)
1st June 2016, 01:49 PM
#18
Lexx
and what have we learnt here, I left the heat shield off the turbo, well somebody did.
Made it easier to fit the beanie anywaylol, Good to hear its sorted
1st June 2016, 09:48 PM
#19
bigguwesty
Even easier when in the scrap pile.
Lexx
ROFLMAO @ the FACT
threedogs
Yerp, beanie wins hands down.
1st June 2016, 09:50 PM
#20
LostBenji
ROFLMAO @ the FACT
Yea Bennie will be on soon.. just funds only allow a fee things at a time..
