Results 1 to 6 of 6
Thread: Mk to gq front guards
    Oct 2013
    Does anyone know if it is possible to fit the early gq front quarters on an mk
    I have a 1986 mk patrol ute, long time reader first time posting so I hope I have this in the right place
    Oct 2013
    Is it true that some of the last mq came out with moulded flared front qauters aswell
    If you look at the evolution from the MK model to the last GQ, you can see all Nissan
    did was first put a small flare on then another flare then a piece of rubber.
    The actual body stayed the same with only the track becoming wider with
    each model, hope this helps
    192 Post(s)
    I have seen a couple of mq/mk with GQ front guards, so assume they go straight on. looks a bit funny on a wagon but ute would be all good.
  6. #5
    Oct 2013
    Yeah I seen a gq at woollies and the front quarters looked exactly the same except with flares but thanks to the govoment it didn't have a rego sticker on it to see the year so I thought I might aswell as the question. Good Mk/mq quarters are hard to come across and it would be good to have moulded flares, thanks guys this has helped
  7. #6
    Patrol Guru
    Apr 2011
    Melton
    They will fit - but I belive you need to change the front panel to match as well - I read it some were.
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
