The first one circled looks like the part that bolts to the bottom rear of the engine, not sure which side, and supports the lower half of the trans. There's one on each side but they're not similar.
Could take pics tomorrow of them both.
The second circle could be for A/C but it's not the same as mine. If it is for A/C, the TB compressor won't fit to it.
John
Yeah I reckon your right about the first one. Just going through the Nissanfast catalog and found them. I suppose mate, make up a list of what you have and what $$$ your after and then, pm it to me. I'll see the mechanic next week. This week I have too much on.
You're clearly in no hurry so let's see what you really need down the track.
I'm in 2 minds about the manifold, I'm thinking it might be better to keep it and bundle it with turbo, crossover stuff, dump. etc if I change the turbo. That makes an almost complete bolt-on turbo kit for someone. With no manifold, nobody would want the other stuff..
John
I would take the a/c pump bracket to suit mate. Just did a quick look around and the pump is the same, for TB/TD and RD28...
Get some prices together mate and send me a pm if you like.
I've just taken a closer look at your A/C bracket (the one you had circled in an earlier pic) and it is the same as the bracket on my TD42T so the TB45E A/C compressor will fit on it.
John
Another FYI, here's a pic of the 2 cast brackets you need that bolt to the rear of the engine and to the trans.
The one on the right is for the RH side.
John
