Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: GU TD42T bolt on engine parts....
    The master farter
    mudski's Avatar
    462 Post(s)
    Quote Originally Posted by jff45 View Post
    Do you mean all the cast brackets?
    I will probably have the cast bracket for the alternator and also the cast bracket for the power steering pump.
    If it is a TD42T factory turbo block, I also have the original oil feed & oil return hoses for the vacuum pump on the alternator.
    Do you have a pic of the LH side of your block?
    Hmm. I took a shite load of pics when the block was here. Over the weekend I will look at the brackets I have and try to work out what they are. The motor is already at the work shop.....
    Its a factory TD42T block btw.
    The master farter
    mudski's Avatar
    462 Post(s)
    Quote Originally Posted by Bloodyaussie View Post
    F%$k you get lucky Mark..... think I am going to run you over... hmmm maybe when you have paid for and completed the build !!!!
    Err why?.......
  4. #13
    Thomastown, Melbourne
    6 Post(s)
    Err why?.......
    Because it would be oh so much fun........
  5. #14
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    Alternator bracket on the left. Power steering pump bracket on the right
    John
  6. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (20th June 2015)
  7. #15
    The master farter
    mudski's Avatar
    462 Post(s)
    Thanks mate. Ill check out what i have tomorrow and try to get some info of tha ac pump.
  8. #16
    May 2012
    Morayfield, QLD
    13 Post(s)
    What turbo manifold are you planning to use?
    I have the original 2 piece cast factory manifold that could be for sale.
    John
  9. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (21st June 2015)
  10. #17
    The master farter
    mudski's Avatar
    462 Post(s)
    Low mount mate and definitely interested in what you have. What else ya got? Lol.
  11. #18
    May 2012
    Morayfield, QLD
    13 Post(s)
    I have the crossover piping but that won't interest you with what you're planning..
    As you mentioned, have a good look at what you need so we get a clearer idea of where we're going with all this.
    John
  12. #19
    The master farter
    mudski's Avatar
    462 Post(s)
    Ok the bracket on the left I have. I don't have the upper adjusting bracket.... The one on the right, it looks familiar, I dont have it in my bunch of photo's. So I will assume no, also the adjusting bracket for the pwr strg pump too... Everything is at the workshop now so I can't check.
    Do you know what the part circled is?
    And is this bracket circle below the A/c pump bracket? Assuming it is....
    Not 100% on the a/c pump pipe fitment though. yet
  13. #20
    The master farter
    mudski's Avatar
    462 Post(s)
    Just add another on the list. Brackets from motor too engine mounts.
