Ok. Peoples. I'm about to embark on a ZD to TD GU conversion and I need a few bits. I'm not really sure on what I'm missing at the moment but heres a list of what I know I need....
Power steering pump and brackets I have...
Power steering piping I have...
A/c Pump and brackets ( I think) I have...
A/C piping Maybe be able to use my hoses???????
Fuel filter head I have...
Bellhousing to suit.....
Engine mount brackets, from motor too engine mount.
Chassis to engine mount brackets I have...
RHS rear engine to trans bracket
Thats all I can think of right now. Its a bit overwhelming on what parts I will need that I don't even know of yet.
Alternator, starter, radiator, shroud, clutch fan and engine fan, turbo and maybe intercooler (depending on whats for sale second hand) I will get new.
I have a power steering pump off the TD42T motor I just bought.
I also have a new high pressure hose I just ordered from Patrolapart before I decided to use the TB45 pump.
I also have a TB45 A/C compressor - it bolts to the bracket on my TD42T so I assume it's the same. It has the O'ring type connections for the hoses.
I'll try to take some pics this weekend.
John
Thanks. Can anyone confirm the a/c TB45 a/c pump will be the same? Assuming if it bolts up and the wiring plugs are the same, it will be yes...
While your taking pics. Can you take some pics of all the "bolt on" brackets? Please. Just so I get some reference of what I have and dont have. Thanks.
Do you mean all the cast brackets?
I will probably have the cast bracket for the alternator and also the cast bracket for the power steering pump.
If it is a TD42T factory turbo block, I also have the original oil feed & oil return hoses for the vacuum pump on the alternator.
Do you have a pic of the LH side of your block?
John
