Results 1 to 10 of 20
Thread: Uhf issues
    Oct 2011
    melbourne
    Uhf issues
    Hi all. Have a uniden din size uhf. Having issues that when receiving incoming transmissions i get continuous static coming through. I can only stop the static by tapping my handset button. Any ideas?
    Do you have a squelch button, may also be loose wire
    Oct 2011
    melbourne
    Does have a squelch button which I've played with. No luck. Only seems to happen when close to the person traveling.
    Nov 2010
    Getting a life...
    38 Post(s)
    The 40 channel and 80 channel dont like talking to each other. Maybe thats it.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    201 Post(s)
    Hmm I've never had any dramas talking to people with 80 channel radios?
    Nov 2010
    Getting a life...
    38 Post(s)
    Oh well. must be just me then.....
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    steve comes over loud and very clear on the 80 ch we have
  9. The Following User Says Thank You to Sir Roofy For This Useful Post:
    katwoman (17th June 2015)
  10. #8
    Patrol Guru
    Apr 2011
    Melton
    It wont be the differance betwen the 40 / 80 channel rigs as long as they are on the same channel. (and between channels 1 - 40)
    40 - channel reciveing a transmission from an 80 channel - the recived audio is lower
    80 - channel reciveing a transmission from an 40 channel - the recived audio is higher, worst case you could get some audio blocking (bit of no audio). But most of the cbs are desiggned to prevent this.
    How i it transmiting? do you have good range - can others hear you a km away? - as you might have a staffed antenna / cable / connector (most often a connector fault).
    When you tap the button and stop the static, do you then hear ok?
    Or are you activating the tranmitter?
  11. The Following User Says Thank You to GQ TANK For This Useful Post:
    katwoman (21st June 2015)
  12. #9
    Jul 2013
    Do you have the unit connected to the cigarette live wire? If so, hook it up to your deep cycle battery directly. I use to have it this way and found that the accelerator / idling from motor was inteferring with the unit when listening. Just a thought.
  13. #10
    Mar 2015
    Quote Originally Posted by GQ TANK View Post
    actully there is a differance the older 40 channel radio's are wide band and the 80's are narrow band if the recive or transmit is not intune it can cause this also sometimes if you are to close to each other it can cause this i have had it happen a few time at work....
