Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 2001 Ti TB45E auto to TD42T auto conversion
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    @Kallen, not sure I understand the question. You can see the PS reservoir in the last photo. Its position is almost exactly where it was on the TB45.
    John
    43 Post(s)
    Yea wow. The genuine td42 the power steering and alternater are swapped to how you have it so the resivour is up at the top easy to get to and the alternater is tucked away under all the intake.
    Morayfield, QLD
    The reason I did it that way is because the TD alternator with vacuum pump won't fit without removing the TB45 A/C hoses.
    You also have to modify the TB45 PS hoses & cooler lines if you use the PS pump on the right side where the TD has it.
    I now have both my TB45 steering & A/C components exactly as they were on the TB45 engine. Didn't need to degas nor lose a drop of steering fluid. I just unbolted them and tied them to the side when I pulled the TB45 out.
    I just had to weld up custom brackets for them.
    John
  5. #14
    Advanced ando89's Avatar
    Mar 2016
    Perth, Western Australia
    Nice work mate how was the electrics not to bad or plug and play?
  6. #15
    Morayfield, QLD
    Electrics for a TD42T are pretty simple so it was easy to use existing wires in the engine bay.
    A lot of the EFI wires are no longer required so you simply cut them out.
    John
  7. #16
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Very neat job all round. Question re the intake plennum. Is there a formula to work out required air volume held by the plennum?
    Has been suggested too much or too little will effect turbo performance. GT 3540 seems overkill on td42. Keen to hear how it spools.
  8. #17
    Morayfield, QLD
    I don't have a GT35/40 on the TD42T. That turbo was for the TB45E project that didn't happen.
    I'm currently fitting a Mamba 16G/6 in place of the HT18.
    From memory, the recommendation is to lift the factory inlet manifold by 50mm
    Edit: I see why the confusion re the XR6 turbo. I was referring to using the manifold on the TD but didn't word it precisely
    John
  9. The Following User Says Thank You to jff45 For This Useful Post:
    Touses (11th March 2016)
  10. #18
    Mar 2016
    Childers QLD
    22 Post(s)
    Ok got the plennum bit,filed for future ref. The mamba 16g/6 any worthwhile advantages over gt 2860 ball bearing?
  11. #19
    Morayfield, QLD
    Quote Originally Posted by Touses View Post
    Biggest advantage is that they've cast the turbine housing to bolt in place of the HT18. Big saving if you've bought an expensive cast dump.
    The TD05H copies seem to be pretty popular for the TDs
    John
  12. The Following User Says Thank You to jff45 For This Useful Post:
    Touses (12th March 2016)
  13. #20
    Mar 2016
    Childers QLD
    22 Post(s)
    Thanks for that lot am filing away info for my current rebuild.Cheers!
