Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Hi All
    Jun 2015
    Hi All
    Hi All im about to buy a 2012 patrol 3l ive been told the engines can blow due to the MAF sensor getting oil and soot on it which can make the engine overheat and crack pistons .Is there an aftermarket item you can buy to stop oil and soot getting to the sensor .Will an air/oil catch can stop the problem ? .Im also thinking of buying a thermal fan for the intercooler are they worth the money if anyone has already done this .
    Thanks in advanced
    Expert LaughingBeagles's Avatar
    Mar 2015
    2 Post(s)
    G'day mate, welcome to the forums. Tell us a little about yourself. I've not heard of this issue but then I'm not your expert. I'm sure someone in the know will be along to answer soon. If not, once your intros are out the way, head to the mechanical section and post there.
    Looking for a 4WD Club in WA that caters solely for Patrol, Safari and Maverick owners? Click here to HERE to visit the Western Patrol Club. Click HERE for the Beagle Mobile Mods!
  4. The Following User Says Thank You to LaughingBeagles For This Useful Post:
    aaron_85555 (11th June 2015)
  5. #3
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day and welcome to the forum mate.
    Sounds like a mixture of two issues. There is a "grenade" issue with early 3l motors but not the 2012 crd model. The MAP sensor probably has nothing to do with making the engine overheat and crack pistons and although it needs cleaning now and again is not an issue as such. An oil catch can may help in keeping the sensor clean but that is not the main reason for fitting an oil catch can. Thermal fan would depend on what sort of driving you are doing IMO. The stock setup is adequate, but some believe in thermo fans on the i/c, larger i/c's and other mods.
    End of long boreing welcome.
  6. The Following User Says Thank You to 4bye4 For This Useful Post:
  7. #4
    Jun 2015
    Thanks guys Yea im getting back into my 4x4s i sold my last one about 8 years ago and ive been itching to get another one ever since .All i have last time was a 4.2l maverick had a 3inch lift & 35s on her was an industuctible rig .But now im a bit older i want to get the 2012 patrol something i can have for 15-20 years plus the only mods i want to do is a snorkel , winch and intercooler fan because ill be doing a lot of beach driving
  8. #5
    Aug 2014
    Kingsley WA
    15 Post(s)
    If your talking 15-20 years I would be replaceing the nissan i/c with a tig welded one. the Nissan crimped will fail and leak at some point along the line. As I said befor weather you go for fan type or larger is up to you but definatly repalce it with a welded one.
  9. The Following User Says Thank You to 4bye4 For This Useful Post:
  10. #6
    Hello and welcome to the forum, as suggested a tigged IC will be fine . as for bang for your buck .
    I dont think you'll get that much more benifit from a larger IC. Money better spent else where
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #7
    Jun 2015
    Ok awesome thanks guys definently something i week look at I've heard the stock intercoolers are rubbish everyone i talk to is saying replace with a tig welded one does anyone know where i could pick up a good one around the brissy area when the time comes.
  13. #8
    Patrol God Stropp's Avatar
    31 Post(s)
    welcome along to the forum, in the search button and put in nads and search away.
  14. The Following User Says Thank You to Stropp For This Useful Post:
  15. #9
    Feb 2011
    Shed
    45 Post(s)
    Gday mate welcome aboard
  16. The Following User Says Thank You to growler2058 For This Useful Post:
  17. #10
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
  18. The Following User Says Thank You to Dhuck For This Useful Post:
