9th June 2015, 09:40 PM
Gq clutch play
Gday guys i recently got some mates to change over the master and slave on my gq while i was away for work since the slave was nackered and the master resevoir wouldn't hold any fluid. Change went fairly smooth and bleeding worked pretty well and they had a steady flow of fluid with no air before closing it all up and the new resevoir holds fluid as it should. Only problem is now the pedal pretty much falls to the floor and can only feel any resistance for the bottom inch. Clutch still seems to disconnect to change gears but doesnt seem to want to return so im having to put my foot under the pedal and manually lift it back up. When i do this it seems to spring back pretty quick and the clutch slams back in pretty hard. I know i wasnt there for the swap but it sounds like the boys did an alright job there just seems to be something wrong.
cheers
steve
1989 Ford Maverick: TB42s Carby, Snorkel, 3" king spring suspension lift, 2" body lift, aftermarket extractors, 33x12.5 mickey t MTZ's, 2.5: Sports Exhaust
9th June 2015 09:40 PM
9th June 2015, 09:45 PM
Sounds like there is air still in the system
13th June 2015, 11:15 AM
How about the spring tension inside clutch master cylinder?
Is your clutch with servo or without servo type?
23rd June 2015, 11:13 PM
Fox7
Its got a booster if thats what you are talking about yeh
2nd July 2015, 01:33 AM
I think you have clutch fork broken, if you are sure there no air.
23rd July 2015, 10:39 AM
clutch fork bent or brocken
16th September 2015, 09:34 AM
Hey mate,
Check clutch hose.
My friend got same story in his land cruiser. When he replace hose with new one. Everything was perfect.
16th September 2015, 08:04 PM
dunno mate but it sounds like you still have air in the system ...
edit: did you bleed it from the inner guard ? there's a bleed nipple in the engine bay passenger side guard near the firewall
