7th June 2015, 12:29 PM
7th June 2015 12:29 PM
7th June 2015, 12:37 PM
Dribble Master
The switch on the right looks like an anti detonation switch. ...............
Just give patrolapart a call about the Jack trim cover
The Following User Says Thank You to Clunk For This Useful Post:
LaughingBeagles (7th June 2015)
7th June 2015, 12:38 PM
Thanks Clunk.... I laughed so hard, I did the coffee through the nose trick...
Looking for a 4WD Club in WA that caters solely for Patrol, Safari and Maverick owners? Click here to HERE to visit the Western Patrol Club. Click HERE for the Beagle Mobile Mods!
7th June 2015, 12:43 PM
hey LB, the switch is for your "idle-up" for when your stationary but need more rev's - eg: winching, jump starting a toyboata, using a PTO (Power Take Off - from the transfer case etc
the jack cover, look for one wrecking on gumtree, and just ask them
proper name is...... "Jack cover thingy.............."
The Following 2 Users Say Thank You to Bigcol For This Useful Post:
growler2058 (7th June 2015), LaughingBeagles (7th June 2015)
7th June 2015, 12:45 PM
woopppsss
my bad
switch on the RIGHT
thats for the heat by-pass
keeps engine warm more than the cabin heater - I think.........
dont have a 3l, so maybe clunky IS right
The Following User Says Thank You to Bigcol For This Useful Post:
7th June 2015, 12:46 PM
Dribble Master
Bloody Col, trust you to come up eith a sensible answer
7th June 2015, 12:49 PM
what sensible answer
the - proper name is...... "Jack cover thingy.............."
LaughingBeagles (7th June 2015), Woof (7th June 2015)
7th June 2015, 01:03 PM
#8
I am he, fear me
It is the Heat Up switch more commonly called "Idle Up"
From the manual...
The heat up switch is located on the lower side of the instrument
panel. This switch is used to speed up the heater’s operation when
the engine is cold.
When the ECM received the heat up switch “ON” signal, the ECM
increases the engine idle speed to 1,100 to 1,200 rpm to warm up
engine quickly.
This system works when all conditions listed below are met.
Heat up switch ON
Engine coolant temperature Below 105°C (221°F)
Shift lever “P” or “N”
Accelerator pedal Fully released
The Following 3 Users Say Thank You to the evil twin For This Useful Post:
Avo (7th June 2015), LaughingBeagles (7th June 2015), Woof (7th June 2015)
7th June 2015, 01:07 PM
#9
I just knew I could count on my WA friends...
7th June 2015, 01:14 PM
#10
Hey Peter, aren't you putting drawers in. You might not want the jack cover thingy. I now store my jack elsewhere.
The Following User Says Thank You to 4bye4 For This Useful Post:
LaughingBeagles (13th January 2016)
