Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Really Uber Dumb Guy question(s) - what are these called....
    Expert LaughingBeagles's Avatar
    Mar 2015
    2 Post(s)
    Lightbulb Really Uber Dumb Guy question(s) - what are these called....
    Ok, 98.9% of you are going to read this and say, "really?".... "com'n LB..." but hey, I might as well go out there and ask the dumb questions.
    First up, my owners hand book does not tell me what the switch on the right is / does:
    Any ideas? I suspect it has to do with the turbo? (yes, I feel like an UberNoob asking).
    My second dumb question is: When I bought my rig, it was missing the cover for the jack at the back. I've not been able to (a) find the right name for it so I can google getting a new one and (b) been able to source one from anywhere.
    Any pointers as to how I can source one would be appreciated.
    Looking for a 4WD Club in WA that caters solely for Patrol, Safari and Maverick owners? Click here to HERE to visit the Western Patrol Club. Click HERE for the Beagle Mobile Mods!
    The switch on the right looks like an anti detonation switch. ...............
    Just give patrolapart a call about the Jack trim cover
  4. The Following User Says Thank You to Clunk For This Useful Post:
    LaughingBeagles (7th June 2015)
  5. #3
    Mar 2015
    2 Post(s)
    Thanks Clunk.... I laughed so hard, I did the coffee through the nose trick...
  6. #4
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    hey LB, the switch is for your "idle-up" for when your stationary but need more rev's - eg: winching, jump starting a toyboata, using a PTO (Power Take Off - from the transfer case etc
    the jack cover, look for one wrecking on gumtree, and just ask them
    proper name is...... "Jack cover thingy.............."
    Tidy Whitey - 99 GU TD42Ti - Diesel Gas, (GUIV Turbo & Intercooler 8Lb boost), 33" Micky T's Baja MTZ's, Dual Batt's, Cargo Barrier, rear draws, HID Super Oscars, winch, Grinch & witch attached and more goodies to come
  7. The Following 2 Users Say Thank You to Bigcol For This Useful Post:
    growler2058 (7th June 2015), LaughingBeagles (7th June 2015)
  8. #5
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    woopppsss
    my bad
    switch on the RIGHT
    thats for the heat by-pass
    keeps engine warm more than the cabin heater - I think.........
    dont have a 3l, so maybe clunky IS right
  9. The Following User Says Thank You to Bigcol For This Useful Post:
  10. #6
    Bloody Col, trust you to come up eith a sensible answer
  11. The Following User Says Thank You to Clunk For This Useful Post:
  12. #7
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    what sensible answer
    the - proper name is...... "Jack cover thingy.............."
  13. The Following 2 Users Say Thank You to Bigcol For This Useful Post:
    LaughingBeagles (7th June 2015), Woof (7th June 2015)
  14. #8
    W.A. (wandering aust)
    It is the Heat Up switch more commonly called "Idle Up"
    From the manual...
    The heat up switch is located on the lower side of the instrument
    panel. This switch is used to speed up the heater’s operation when
    the engine is cold.
    When the ECM received the heat up switch “ON” signal, the ECM
    increases the engine idle speed to 1,100 to 1,200 rpm to warm up
    engine quickly.
    This system works when all conditions listed below are met.
    Heat up switch ON
    Engine coolant temperature Below 105°C (221°F)
    Shift lever “P” or “N”
    Accelerator pedal Fully released
  15. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    Avo (7th June 2015), LaughingBeagles (7th June 2015), Woof (7th June 2015)
  16. #9
    Mar 2015
    2 Post(s)
    I just knew I could count on my WA friends...
  17. #10
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Hey Peter, aren't you putting drawers in. You might not want the jack cover thingy. I now store my jack elsewhere.
  18. The Following User Says Thank You to 4bye4 For This Useful Post:
    LaughingBeagles (13th January 2016)
