7th June 2015, 10:29 AM
#11
Rotaredom
Hodge,
Multi-quotes have the ability too be inserted in other threads / posts so once you muti quote a post the post is stored in a cookie which is never cleared until you clear it manually. So as much as I see it as a bug in VB it is probably working how they intended it 2 work.
It will probable easier too show you an example of how multi quote messages work.
Example 1
Multi quote any post in this thread then hit the the "Reply to Thread" Button.
This will bring your selected "multi-quoted" post into the "Quick Reply" type a reply and select the "Post Quick Reply" button.
You will notice the post you "multi-quoted" is still ticked
.......this is were the problem is as it will be left ticked until you either log out of the forum ( just a guess as have not tested this yet ) or you deselect you multi-quote manually.
Example 2
Goto any thread / post other than this thread and multi-quote a post
Come back here and select the "Go Advanced" button, you will notice under the box you type in this text "You have selected 1 post that is not part of this thread. Quote this post as well, or deselect this post."
Selecting "Quote this post as well" will put it into your text box and after you post your message will automatically clear your cookies / deselect the mutli-quote from the other thread.
Selecting "Deselect this post" will not enter the multi quoted post and after you post will also automatically clear your cookies / deselect the mutli-quote from the other thread.
Hope this makes some sort of sense 2 you
Toddie
The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
Hodge (7th June 2015), the evil twin (7th June 2015)
7th June 2015 10:29 AM
7th June 2015, 11:02 AM
#12
Hey Toddie.
You have gone into way too much effort for this little annoyance. So thanks for that! And yes I now understand exactly what you mean. I have actually attempted to replicate this bug in another forum, using vBulletin and the same issue occurred.
To me it is not an problem as such, as it is a simple matter of deleting the unwanted quote text (if noticed). It's just annoying when I quote something quickly, and NOT notice the extra multi-quote inserted unintentionally, and then click reply and only then notice whats happened... Or NOT notice it and whoever reads the reply after, gets confused as to why did I insert that unrelated text.
So it's a matter of editing the post and deleting the unwanted quote. No biggie!
I merely wanted to see if I was the only one getting the bug, ruling out my browser etc... But it seems widespread.
Thanks again!
The Following User Says Thank You to Hodge For This Useful Post:
NissanGQ4.2 (7th June 2015)
7th June 2015, 11:19 AM
#13
7th June 2015, 11:23 AM
#14
Definitely understood. As another example few moments ago. I went to post something in the "What has made you Angry Today???" thread.
And the same thing happened... So I manually went back to the post that was multi-quoted and found the multi-quote button still to be ticked. Which explains the cookie theory.
So far I assumed that once you multi-quote something, and post a reply including it, i automatically gets unticked . But not in this case.
So manually un-ticking the post, cleared it as well... Happy times!!
Thanks again!
