Results 11 to 20 of 22
Thread: Who here cryovacs their meals ??
    Aug 2011
    River Heads Q
    4 Post(s)
    Yep also use one, great for home and camping to reseal ....... i got one thats 12v & 240V
    Hi Clunk
    What brand is it and how good is it on 12volt?
    Quote Originally Posted by Wizard52 View Post
    Hi Clunk
    It's a dometic and I must admit, I haven't tried it on 12V yet
  4. #13
    201 Post(s)
    Seems to do the job on 240V alright though? We want to buy one and will probably be used 99% on 240V before leaving home but the option of having 12V is always good.
  5. #14
    sure does, haven't had anything to compare it to but so far all good
  6. #15
    I have the standard old everyday jobbie I use at home prior to tripping around the place.
    In the Van I have one of these style handheld Vac Sealers for sealing anything while tripping around.
    These have reuseable bags so need a wash etc when I get back home but on a trip are very versatile, work great and take up hardly any room
    Link for illustrayion only (but looks a lot like the one I have)...
    http://www.ebay.com.au/itm/Portable-...cAAOSwYHxWLpSV
  7. The Following User Says Thank You to the evil twin For This Useful Post:
    Wizard52 (28th January 2016)
  8. #16
    Dec 2012
    Looks very similar to my aldi one.
    One thing I found though is when the steak/snags have thawed in the cyro bag, always slow thawed in fridge,
    there seems to be some air space in the bag.
    Maybe the quality of the bags (ebay) or I need tp double seal.
    Apart from that, great machine.
  9. #17
    43 Post(s)
    Love ours.. not 12v though..
    Use it every..
    Used probably 5 rolls in only a few years..
    But I've had to mod mine. Inside it has a pressure Reg valve sorta thing.. this broke in mine.
    I made a small plug with a pin prick hole.. took a bit to get the hole right so it didn't over pressure to quickly and trigger the seal to early but after half hour I've got it working better than new imo..
    Wouldn't be without it now..
    12v to me would be handy if you caught a decent fish
  11. #19
    43 Post(s)
    The sucking bit I think would be fine.. it's only a small piston pump with a couple of one way valves..
    It's the sealing element that you'd have to investigate..
    Should have power usage (watts) on the unit
    Expert clubbyr8's Avatar
    Penrith, NSW
    Aldi are selling theirs again on Saturday 6th February for $69.99. Bags or rolls are $14.99 - Bags 40 pack @ 22 x 30cm wide and rolls 2 x 5m rolls @ 28cm wide....... Might have a look..
    GROOVY GUVII
