Results 1 to 10 of 18
Thread: Need thoughts on braking issues
    Patrol Freak Gecko17's Avatar
    Mar 2013
    Hi all,
    Over the last couple of months, I have had an issue with the braking ability on my patrol and am my wits end as to the cause. I have a 06 GU IV wagon with a 6.5l ICTD V8 with a chevy auto as well. I am currently running 33in tires. When I brake, the patrol pulls up eventually but nowhere near where it should. It slows up a lot quicker under 60km/h.
    This is what has been done so far...
    Replaced all brake lines with braided brake lines (for ABS)
    Replaced all pads
    Replaced master cylinder with OEM
    Replaced all brake fluid and bled lines
    I haven't replaced the rotors as they are in good condition
    Calipers are working correctly
    I took it in the the local Nissan dealer and they had a look at it and then said that, in order to analyse it, it would cost a lot due to the amount of time need to find the problem, so I should take it to a brake specialist. (to be fair to Nissan, they looked at it for a couple of days and didn't charge me for it)
    Potential problems:
    Air lock in the ABS unit
    ABS unit not working
    O-rings on calipers rolled in
    Vacuum pump not working properly (it is not a constant vacuum, more like an intermittent vacuum)
    My mechanic spoke to a brake specialist, who made the comment that patrols have craps brakes! Is this the case? I am pretty sure that my 98 GU stopped pretty damn well.
    I have heard that I can upgrade to the brakes on the 4.8l but then also have to change rim size to 17in and really don't want to do this unless absolutely have to.
    Is there something I am missing?
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
    Hmmm... the 60 KPH comment is interesting.
    The vacuum comment even more so.
    The booster should hold steady vacuum so maybe the check valve is faulty
    That can be a tad hard to sort out without test gear
    You could find somewhere safe and see how many brake applications you have with the engine turned off
    Long shot but a faulty ABS bypassing some pressure maybe?
    Mar 2013
    Thanks ET. I was hoping that you would see this as wondered if it was a conversion thing, with the vac pump...
    Which pads did you fit??
    Mar 2013
    Same as before 3D. Does it make that much of a difference?
    It did with BA made a huge difference,
    DBA are a sponor here with a post on this forum 1st page maybe send them a PM
    a softer pad may be better than say a black/green pad.
    My mate with the extended GU has kevlar pads and swears by them bit smelly at first
    but stops on a dime now.
    Rotors are cheap enough these days to change every two years or so
  8. #7
    From what i have found using tb48 calipers and discs you can still use 16inch rims. They are 10mm larger in diameter. Not much. But all lot in braking terms.
    I dont know about the rears though, as the tb48s had the hand brake in the caliper, not on the tailshaft. Whether they still could be fitted, im not sure.
  9. #8
    @ GKO if your select the right components for your brake,
    bleed it correctly using the correct fluid it should stop.
    You would only be a bit heavier than a standard patrol with mods
    wouldnt you say 200kg plus heavier
  10. #9
    Expert billyj's Avatar
    gordon
    3 Post(s)
    as long as the caliper pistons are moving freely and the slides are well lubed and moving freely then my first thought is keep bleeding, patrols are a complete bitch to get bled properly, you can have what feels like a nice hard pedal but still have air in the system, i think it took about 2-3 hours to get my gq fully bled after a caliper reco and new front lines.
  11. The Following 2 Users Say Thank You to billyj For This Useful Post:
    Gecko17 (4th June 2015), the evil twin (4th June 2015)
  12. #10
    Quote Originally Posted by Gecko17 View Post
    Dunno, maybe, maybe not... other posts about the things being a turd to bleed are 100% correct as well.
    Maybe find a nice safe bit of road/car park and;
    Pull the ABS fuse... (good tip for off roading as well, non ABS braking stops heaps quicker in the weeds using "brush and bury" technique).
    Do some emergency braking runs and see how much and what lock up your getting and how much pedal effort.
    That will start to help isolate it down to poor vacuum, unbalanced pressures, dodgy bias valve, cold pads etc
  13. The Following User Says Thank You to the evil twin For This Useful Post:
