Yes,more questions.. I've seen several threads talking about the tacho sensor in the front engine cover but there's a blanking plate on the td42T import engine I have.
I found this brass sensor under the IP with 2 wires broken off and the wires hanging beside it with the rubber cap.
Is this the tacho signal on some of these engines?
John
It would make sense as that is where the ip gear is and the ip spins at half engine speed. Just like the cam.
