Results 1 to 2 of 2
Thread: Water storage dilemma
    In my camper I have a dolium 55ltr water tank that gravity feeds via a 1/2" tap on the out side.
    flow rate is adequate but could be better.
    This tank will fit across the floor in the back if I go fishing solo and leave the camper at home.
    What I want to do is fit a water tank [black caravan style] under the camper to help balance
    the weight a bit better. Being under the camper I will now require a pump of some description to draw water up to the tap,
    Fill point will be where the fuel filler was via a plastic deck fill from a boat. what i need to know is what size pump is right ?
    I've seen cheap ones that will do 5 LPM is that slow or ok.? I have plenty of 12v power available. simpler the better
    http://www.ebay.com.au/itm/251677365...%3AMEBIDX%3AIT
    http://www.ebay.com.au/itm/190561357...%3AMEBIDX%3AIT
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    Hi mate,
    I run one of these in my camper and it works well. I have a 59 liter water tank that sits behind my axles. I have needed to run a re stricter on it to slow the water flow down to 2.5 liters per minute for the sink.
  4. The Following User Says Thank You to blocko05 For This Useful Post:
    threedogs (29th May 2015)
