Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Is this kind of imported TD 4.2 worth buying?
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    I gave this mob a ring anyway and they say they don't know the mileage on the engine because the engines are already out when they buy them.
    They'll accept $6800. I'm tempted..
    Any opinions?
    John
    Quote Originally Posted by jff45 View Post
    Any opinions?
    What sort of warranty do they offer?
  4. #13
    May 2012
    Morayfield, QLD
    13 Post(s)
    3 months.. but it will be the kind of warranty you get from wreckers "no good? Ok, bring it back and we'll give you another"
    I have to accept that there's some risk as with any used engine..
    John
  5. #14
    North brissy
    Any opinions?
    Conversion wise its not a bad idea. It has the required flexplate which is hard to get. You will just need a torque converter. The td will bolt straight to the tb45 auto and also uses the same brackets on the chassis for the engine mount.
    Will they allow you to check the engine prior to purchase?
  6. #15
    May 2012
    Morayfield, QLD
    13 Post(s)
    The TB45 torque convertor will bolt to that flexplate. I'll just need to get it opened and have the stall lowered to around 1800. I have a spare TC that has only done 22k.
    It should also have the TPS on the pump. Pretty sure I can see it.
    They claim they fire them up and do a CO2 test. You can see "CO2 passed" scribbled on the heatshield. I was told they don't do compression test if CO2 is good.
    I think the only inspection they'd allow would be looking under the oil filler cap.
    What else can be checked?
    John
  7. #16
    North brissy
    All good. Just if they would allow you to compression check and also throw a gauge on it to check oil pressure etc.
  8. #17
    May 2012
    Morayfield, QLD
    13 Post(s)
    I doubt they'd allow it before buying it. I can always do it when I get it home. They give 3 months warranty.
    I've been reading for years how bulletproof these things are supposed to be.
    John
  9. #18
    North brissy
    Yeah it should be fine. Its just the way I am sometimes i can get carried away but I just dont like seeing people get the short straw.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
    jff45 (29th May 2015)
  11. #19
    May 2012
    Morayfield, QLD
    13 Post(s)
    I appreciate that but I'm going into this with eyes wide open so I accept what I judge to be a minimal risk.
    It just has too many things going for it:
    - TD42T factory turbo with auto flexplate (different crank so ZD30 flexplate doesn't fit). I believe Wholesale Autos sell these for $750.
    - Has the factory oil, water & trubo oil return orifices in the block. Metal banjos are in place with metal lines.
    - Has boost compensated pump
    - Has TPS on the pump for the auto trans
    - Has factory manifold and turbo so only really needs an IC added in the meantime.
    As it is originally from an auto vehicle, I feel there is less chance of it having been flogged.
    As an import, there's also a very good chance that it hasn't lugged a 3 ton caravan 30,000 kms around the country - as it's likely to be doing next year..
    Am I talking myself into this? You betcha! :-)
    John
  12. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    Clunk (29th May 2015), Maxhead (28th May 2015)
  13. #20
    May 2012
    Morayfield, QLD
    13 Post(s)
    Bought it this morning, picking it up with my trailer Monday afternoon..
    I'm going to miss my Ecutalk and my wideband gauge :-)
    John
  14. The Following User Says Thank You to jff45 For This Useful Post:
