Hey guys I have a gu cab chassis with a massive tow bar( non Reese hitch) used to tow a small tractor and trailer. I don't tow and want to remove it as it gets caught on everything. I'm trying to work out what recovery point I can get for the rear. In the middle of the chassis it has the 4 bolt holes which seem to be in exact same position as the wagon factory short tow/tie down point. Is there a aftermarket tow point I can purchase for this spot or will the same as the front plates bolt to the 3 bolts on the side where the tow bar boots to
GU DX Cab Chassis TD42t non intercooled, 3 inch lift, genuine steel winch bar, 33" Pro Comp All Terrains , 3"turbo back exhaust, Icom IC 400pro UHF, 12inch LED light bar, 42" light bar
Future mods: Intercooler, more boost, dual batteries, drop links for sway bar
Cheers mate I knew I had seen them somewhere before
