Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: How to clean water tanks?
    Nov 2014
    Waikiki, WA
    Re: Caravan tanks mentioned earlier.
    Am always keen to check everything out so if Murphy pops up on a trip will have an idea how to get out of trouble.
    I dropped the stone guard and one or the tanks and found when the tanks were fitted someone had just drilled a hole through the top of the tank for a breather and it was open to the elements.
    Fitted gauze breathers to both tanks to keep the ants, hornets and dust out.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
    Aug 2011
    River Heads Q
    4 Post(s)
    Quote Originally Posted by Nightjar View Post
    I have drilled small hole in top of each tank and attached a breather hose to inside of top of canopy just to make it more convenient by not opening filler plug each time I want water.
  4. #13
    Jun 2015
    You can use any type of white vinegar to remove scale and chlorine tabs to disinfect
  5. The Following User Says Thank You to yazz22 For This Useful Post:
    Wizard52 (19th June 2015)
