Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Reseting a tubeless tyre using Butane Gas.
Hybrid View
    579 Post(s)
    Here's a sure fire method that Michael Olsen used to great success far too many times on their last trip. The usual disclaimer applies. If you use this method you do so at your own risk. (Don't try this at home kiddies!)
    Please note that this tyre is firmly secured to the spare wheel mount on the trailer while executing this manouvre.
    If you only have to re-seat one side of the tyre, use less gas then you would if reseting both. Remember that Butane is heavier than air and will pool in the bottom bottom of the tyre.
    1. Take the can of butane out of your little camp cooker. Place the nozzle from a can of WD40 (flyspray can, anything) on the very top.
    2. Take the valve out of the tyre but keep it and the 'supatool' handy at all times.
    3. Brush a little soapy water around the bead of the tyre and make sure that the bead and rim is clear of any dirt and twigs etc.
    4. With a packet of matches ready to strick and one out to light, spray the butane inside the tyre and then stand back, light the match and throw it. KEEP YOUR FINGERS AWAY from the bead.
    5. Tyre will expand onto the rim due to the expanding vapour ignition. The tyre will suck the displaced air back through the valve. Allow it to do this then screw in the valve, attach your compressor and get it pumping.
    One other piece of advice, if it does not go pop the first time, make sure the lit match that has fallen inside the tyre is out before you reapply the butane gas.
    haha....! It's an easy method and works well.
    Aug 2010
    Wow, has anyone done this before?
    SUCH IS LIFE Maxhead's Avatar
    ACT
    A bit dangerous but very effective by the looks of it. Never done it myself but will keep it in mind.
    ________________________
    ______ 2017 D-Max _______
    Banned
    Quote Originally Posted by NissPat View Post
    Agreed............... it sure would beat walking though
    Nov 2010
    seen it done when one bloke in our group driving a 44" dodge ram 3500 almost lost the hole tire of the wheel. and after 20 minutes digging in the snow there was finally enough space to do this trick. otherwise the car would have been stuck in wasteland
  6. #6
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Airoguard or Rid works just fine too!!
  7. #7
    Oct 2010
    bathurst nsw
    yeah i have seen my dad do it a few times on truck tyres. it does work well but i have never really had a problem with the smaller car tires.
  8. #8
    Sep 2010
    on the coast W.A.
    and if ya stuck, ya can use VEGEMITE to seal the bead, done it and works well.
  9. #9
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by the ferret View Post
    For real?? That's outstanding ... love the whole "necessity breeds innovation" aspect of four wheeling!!! LOL ... makes sense I suppose - just plugs up the small leaks ... not sure it would taste so good on my sangers post use though!!! LMFAO ...
  10. #10
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    Anything is worth storing in memory banks, even if it only comes in handy once for an emergency, just keep it safe.
    Tim
