16th March 2013, 12:48 AM
#41
That trick became very popular after Top Gear Artic Adventure! However, in one of stories that followed about guys from Artic Trucks they were discussing this particular method...
One of the guys honestly say that they had done it just for the show, and would never do it again, as it is VERY DANGEROUS! He also mentioned a mishap he and his friend had had, blowing up the tire, fender and almost putting whole truck on fire...
So, use a compressor instead!
The Following User Says Thank You to misha1973 For This Useful Post:
BigRAWesty (16th March 2013)
16th March 2013 12:48 AM
24th May 2013, 08:24 PM
#42
27th June 2013, 04:51 AM
#43
I've done this many times Very easy to do when you have a lot of tyre stretch. Be aware and watch your fingers!
25th August 2013, 12:32 AM
#44
14th July 2014, 01:11 PM
#45
You can also use under arm deodorant in a spray can.
28th September 2015, 10:42 AM
#46
Used this idea a few times, my mates are always shocked that it works haha
8th November 2015, 10:09 AM
#47
Late reply but yes, same as mentioned previously, I have successfully used deodorant (less "volatile" then butane). I used it on one of my mudder's that wouldnt get on the bead at all. Can't say id try it on lower profile style 'car' tyres ever though...
17th January 2016, 09:14 AM
#48
I recently was out going for a wheel with a local Facebook page n popped a tyre off a rim only thing we had was lighter fluid so we thought why not will give it ago worked a treat sprayed a couple squirts in the tyre n flicked a lighter n bobs ya uncurls the thing that amazed me was it put 30 psi in the tyre I couldn't believe it
17th January 2016, 10:36 AM
#49
I have also done this many times using fly spray on them kiddy atvs have tried with compressor but no go bit of fly spray an it's done in a sec
