Results 11 to 20 of 23
Thread: New guy with no idea
    Patrol God Stropp's Avatar
    31 Post(s)
    welcome along mate, now you can join the oldies that have no idea as well as clunk said 4.2 efi.
    Feb 2011
    Shed
    45 Post(s)
    G'day mate welcome aboard
  4. #13
    Patrol Guru SonOf's Avatar
    Dover, Tasmania
    Welcome aboard mate - you will learn heaps here. I think I have graduated to knows enough to really muck it up :-)
    Seemed like a good idea at the time
  5. #14
    May 2015
    Brisbane
    Its some sort of cloth seats and foam.
    Thankyou for the welcome guys
    So now I know its 100% a 92 GQ EFI sucker i can start ordering the parts in.
    Got a long list of things to order in be cheaper me doing it then paying a mechanic doing it.
  6. #15
    May 2015
    Brisbane
    So i have a list of parts I need. Can someone here confirm that the links below match the the list in the picture?
    FRONT BRAKE PADS - http://www.patrolapart.com.au/produc...ssan-patrol-2/
    ROTORS - ???
    P/S HOSE (HIGH PRESSURE) - http://www.patrolapart.com.au/produc...ing-hose-gq-2/
    TAPPET COVER GASKET - ???
    CLUTCH SLAVE CLY - http://www.patrolapart.com.au/produc...trol-gq-amp-2/
    LHF AXEL SEAL - http://www.patrolapart.com.au/produc...e-front-hub-2/
    WASHER JET MOTOR - http://www.patrolapart.com.au/produc...ront-washer-2/
    NOTE: I couldn't find anything for Rotors and Tappet cover gasket.
    However I'm 99% sure this http://www.patrolapart.com.au/produc...ipe-gq-tb42-2/ suits the part I have tapped up beccase it cracked when myself and a friend were changing the engine mounts
  7. #16
    May 2015
    Brisbane
    Anyone? Is this right?
  8. #17
    Beginner Gertie's Avatar
    Jun 2015
    Hamilton Vic
    Hi omfgitzdav,
    Welcome to the forum, I'm a newbie joiner but have been watching and learning for a few years now.
    I've started off small but have learned heaps from the threads on this forum, enough to know what I can do myself and what I might need help with.
    If you have look through the threads and search up the parts in the search bar you will find plenty of info and photos, from there you can make your own mind up whether to tackle it yourself or not.
    Good luck
  9. #18
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day and welcome to the forum mate.
  10. #19
    Hello and welcome to the forum,
    jump in anytime and enjoy
  11. #20
    Expert billyj's Avatar
    gordon
    3 Post(s)
    mate pretty much everything you need except the ps hose and air intake duct can be obtained from you local repco/bursons which should save you a bit of coin on freight.
    as for the front axle seal if its leaking oil at the knuckle means the inner seal located in the skinny part of the diff just before the knuckle is leaking and you need to dismantle the whole corner to change it, your going to need a full swivle hub kit, and need to clean and regrease the wheel bearings and cv joints, its not a hard job but it is quite messy
