Results 1 to 10 of 14
Thread: A fix to your speedo issues
    Advanced Mudboss's Avatar
    Nov 2011
    Port Augusta West South Australia
    Well after much research I’ve found out that to correct your speedo, I replaced my speedo cog from a 16 tooth to a 15 tooth for $50. But the 14 tooth cog is a different setup. It dropped my speedo by 5km. You can buy a marks adaptors Speedo correction kit for around $240. But I’ve found a speedo correction kit from Jaycar for $50. Looks like a bit of set up work and I haven’t fitted it yet. I’ll let you all know.
  2. The Following 5 Users Say Thank You to Mudboss For This Useful Post:
    AB (13th May 2015), Clunk (13th May 2015), Family4x4 (14th May 2015), my third 256 (15th May 2015), Woof (13th May 2015)
    Whyalla SA
    Quote Originally Posted by Mudboss View Post
    If you have to drop from the standard black cog to the 14 tooth one you have BIG problems with the computer and its software.
    Are you running standard 17" rims and tyres?
    Aug 2010
    adelaide
    i drive off the gps no mucking around and it has speed alert sound when you are speeding
    OH LEATHER IS NICE
    Aug 2010
    Adelaide - Northern Suburbs
    Interested to see how this goes ......
    We're about 108km/h when speedo reads 100km/h ..... resulted in a very expensive ticket a few weeks ago
    Been using speedo from GPS but found it fluctuates a lot, so hard to be efficiently driving close to the limit, without risk of throwing more money away.
    2006 GU ST 3.0td manual. CTEK 250S Dual Battery - Ironman 65L Ice Cube - Pioneer AVH-3600DAB - Tough Dog Adj 45mm Shocks, springs and HD steering damper - Airtec Snorkel - King Brown 3" exhaust
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    you got done for 8km over? Cop must have been having a bad day.
    Aug 2010
    It was before we realised it was 8km over .... must have been doing about 7km over, as got done for 15km over ..... sad times!
    Although it was from her radar in her moving vehicle against our moving vehicle .... i do wonder about the accuracy.
    Nov 2011
    My 03 patrol is allowable +/- 10% but anything made after that is -10% only. I had to drop my speedo because im running 35" tyres now LEGAL, engineer signed off on it the other day.
    You can drop down to a 15 tooth speedo cog, but ill let you know how this Jaycar speedo correction kit goes once i fitted it.
  10. #8
    464 Post(s)
    I've had this snip cut and paste into a info word doc I keep on my pc. I can't remember where I got it from but this is what it says....
    The standard pinion speedometer gear on a 3.0L GU Manual has 17 teeth and in my case my speedo is reading 6% below the actual speed.
    So to calculate the correct gear:
    Standard Gear = 17 Teeth
    Speedo Error = 6% Below
    6% of 17 = 1.02
    Number of teeth Required = 16 (17-1)
    Of course if your speedo is reading higher then the actual speed then you need to add teeth.
  11. #9
    Aug 2010
    adelaide
    found this chart in one of the threads
    Thanks to ET for the table, this the pinion gears table for speedo correction at the gearbox.
    Diff ratio Tyre size Speedo gear (pinion) Part Number 32703 - 31G 17
    Change last 2 digits (in boldface) for gear you need using the table below.
    Be aware that is manuf spec so speedo will probably overread slightly IE at 100KPH GPS the speedo will possibly be 103 maybe 104 KPH as req'd by ADR's
    Your diff ratio will be on the vehicle build plate
    3.9:1 Ratio
    TyrePinion
    31 16
    33 15
    35 14
    37 13
    4.11:1 Ratio
    31 17
    33 16
    35 15
    37 14
    4.375:1 Ratio
    31 18
    33 17
    35 16
    37 15
    4.625:1 Ratio
    31 19
    33 18
    35 17
    37 16
    which is in this thread
    http://www.nissanpatrol.com.au/forum...orrection+gear
    OH LEATHER IS NICE
  12. The Following User Says Thank You to my third 256 For This Useful Post:
    mudnut (21st May 2015)
  13. #10
    Expert janderson's Avatar
    Bearii Vic
    VicRoads Customer Service commented on your Wall post.
    VicRoads Customer Service wrote: "Hi Jeff – ADR 18/02 specifies for vehicles manufactured after January 1995 must have a speedometer that indicates the actual vehicle speed, for all speeds above 40 km/h, to an accuracy of ± 10 per cent. If your speedometer isn’t accurate you can speak to your manufacture regarding calibration or to a VASS engineer as well. Regards - Nathan"
    1st G60 Then MQ Now GU
