Results 11 to 20 of 26
Thread: LPG System Removed to Space for Duel Battery and Long Range Tank
    Expert Agronaught's Avatar
    Sydney, NSW
    I've already got the 70l sub tank so a 95l would probably be ample for now. The LPG range has gone from bad to worse, and I refuse to spend more on it beyond ripping the bloody thing out.
    I've got a trip in June, then nothing till September so time to order all the bits I'll need.
    Cheers.
    49 Post(s)
    Quote Originally Posted by Agronaught View Post
    Cheers.
    How bad are the figures?
  4. #13
    @ GUMAD IMHO I think you have done the right thing, OOI can you weigh what you have stripped out?.
    Should be interesting , These motors are not designed to run on gas, and valve recession is a big factor
    Gas burns way too hot I have plenty of melted carbies here from suffering a lean out.
    @ Argonaught even with a 75ltr and 95ltr you should get what 1000-1100 ks from a 4.5 or 4.8 on the hwy?
    not high country or Simmo
  5. #14
    Sydney, NSW
    800 city, 1k offroad of thereabouts. Depends on how many cruisers are in the party.
  6. #15
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Id kill for that. I get roughly 350km to 100 litres of LPG and 150km to 30 litres of petrol
    Lucus30's 1999 GU ST TB45E
  7. #16
    49 Post(s)
    That's 95+70=165 LTS, of petrol, right, or is that gas+.70=?
    I'm about 100km more on gas and about the same on patrol.
    Runs ok on both fuels, petrol a little better
  8. #17
    Sep 2013
    16 Post(s)
    Probably because yours in injected. I suspect that would be the difference
  9. #18
    49 Post(s)
    Wouldn't have thought that it would be that much if a difference.
    Anyone else running gas injected? Would like to know what your getting.
    Maybe your right foot is heavier that your left......
  10. #19
    Sep 2013
    16 Post(s)
    My right foot is not heavy ha ha. I guess it could also come down to the majority of its use is 4wding
  11. #20
    being injected would only give you a more efficient gas delivery system.
    So a tad more power, I think you should aim for 400ks out of 100 usable gas
    Something not right IMO if you're only getting 350, use "Y" pieces instead of "T" pieces , creates a
    better flow for the water and less cavitation
    http://www.ebay.com.au/itm/171419212...%3AMEBIDX%3AIT
