Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: what are the limitations with winches and water ?
    Patrol Guru
    May 2011
    mackay former alice boy
    Guys can you run a Runva xp 11000 with every thing submerged ie winch and control box and just use the remote .Prepping for Cape trip next year so working out recovery gear to take .
    U have 4 choices in life :U can like it; lump it; love it or shove it, take your pick and stick to it !
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I've never needed to myself but have read that plenty have done it
    Lucus30's 1999 GU ST TB45E
    Patrol Guru
    May 2011
    Thinking Nolans if first across that's all Lucus
    Sep 2013
    16 Post(s)
    Quote Originally Posted by dads tractor View Post
    Hey mate. For Nolan's apparently the best place to be is first. Once its all been stirred up is when people get stuck. Again not talking from experience its just what I've read
    I'm sure others will comment with more experience
  6. The Following User Says Thank You to lucus30 For This Useful Post:
    dads tractor (9th May 2015)
  7. #5
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    I heard its the 3rd car in line that usually gets into trouble but I don't have any direct experience. I think its good advice to let things settle rather than rushing into it straight after the car in front.
    2007 DX CRD Wagon - EFS 2" lift, BOSS Chassis Brace Kit, Steel Bull Bar, Runva 9500-Q winch, FyrLyt's, Rock Sliders, Rear bar with wheel and twin jerry carriers, Drawers, Fridge slide, dual battery, Red Arc BCDC 1220, Red Arc EGT/Boost gauge, Scangauge, Uniden UHF, Prodigy P2 brake controller, CC Intercooler, Pacemaker 3" zhaust, HPD Dawes, ECU Remap.
  8. The Following User Says Thank You to Rock Trol For This Useful Post:
    dads tractor (11th May 2015)
  9. #6
    Would depend what time of year you go,
    we went early September and had no problems
    at all. Ever drove across the Jardine
  10. #7
    175 Post(s)
    I've read somewhere in general winches can run fine under water for a certain time... It's when it gets out of water, that it's important for it to have drain holes to let any water that's got in, OUT.
    And then there is the fully sealed (supposedly) winch units.
  11. The Following User Says Thank You to Hodge For This Useful Post:
  12. #8
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Personally if planning on sinking it, remote mount the solenoid under the bonnet.
    Easy to do. One less thing to worry about then
  13. The Following User Says Thank You to BigRAWesty For This Useful Post:
  14. #9
    Thomastown, Melbourne
    6 Post(s)
    Is it a solid state solenoid.. if so it need not matter.. but the wireless remote unit may be a different situation depending how well the unit is sealed.. maybe move that under the bonnet?
  15. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  16. #10
    You can pressurize the winch with a few pounds of air to stop water getting in, easy enough to do
    using an air horn pump, needs very little psi to work.
    Some even do this mod on a petrol dizzy for river crossings
