Results 1 to 4 of 4
Thread: turbo manifold removal
    Expert luvpsi's Avatar
    ive had a look at my manifold etc myself but was just wondering if it is possible to remove turbo manifold on td42t with turbo still attached as I'm only replacing the manifold to head gaskets and the dump pipe gasket.
    GU DX Cab Chassis TD42t non intercooled, 3 inch lift, genuine steel winch bar, 33" Pro Comp All Terrains , 3"turbo back exhaust, Icom IC 400pro UHF, 12inch LED light bar, 42" light bar
    Future mods: Intercooler, more boost, dual batteries, drop links for sway bar
    22 Post(s)
    Yes it is, a pain but do-able,
    Anti sieze all the studs, nuts and bolts before it goes back on too.
    96 GQ coil/Cab
    08 G6eT
    will do thanks mate
    Expert billyj's Avatar
    gordon
    soak all the nuts in wd40 or similar daily for a few days before you try remove it, should reduce the chance of snapping a stud
