Results 1 to 10 of 10
Thread: Mounting rubber flares
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Hey all
    http://www.ebay.com.au/itm/Rubber-wh...item43d971a8dc
    Just wondering if anyone has mounted rubber flares to the wheel arch using just the existing screw holes. Not keen on drilling new holes or Tek screws.
    Thanks all
    Andy
    581 Post(s)
    I don't think it would work only using the existing holes mate.
    Oem flares are a hard compound and flexy flares are a lot softer.
    You could try it out but I reckon you'll have sagging between the holes.
    I didn't like drilling holes either but used ss rivets and silastic on the rivets when putting them on.
    Ensure a tighter spacing of rivets on the more tighter curves of the arches too.
    In fact thinking about it more I reckon it would look like a bag of poo using the existing holes mate.
  4. The Following User Says Thank You to AB For This Useful Post:
    Parksy (29th April 2015)
    Jan 2013
    Nowra NSW
    5 Post(s)
    Cheers Andy. Trying to visualize it, and I think you're right. But SS rivets and silastic is a great idea.
    581 Post(s)
    Quote Originally Posted by Parksy View Post
    and washers on the rivets too mate, it works a treat!
    No open exposure to rust, no screw ends under the flaps. I always need to get my hands under there when cleaning mud and its a nice clean smooth finish.
  7. The Following User Says Thank You to AB For This Useful Post:
  8. #5
    581 Post(s)
    Take your time on ensuring closer rivets in the curves mate, minimum 100mm on curves and maybe 150mm on straights.
    Stupid new phone won't let me do multiple photos.... My car is a bit dirty...lol
  9. The Following 2 Users Say Thank You to AB For This Useful Post:
    Clunk (29th April 2015), Parksy (29th April 2015)
  10. #6
    581 Post(s)
  11. The Following 2 Users Say Thank You to AB For This Useful Post:
  12. #7
    581 Post(s)
  13. The Following 2 Users Say Thank You to AB For This Useful Post:
  14. #8
    Jan 2013
    Nowra NSW
    5 Post(s)
    Cheers for that. I like them a lot. What size flares are those? Do they hold their shape?
  15. #9
    581 Post(s)
    Bush ranger 65mm flexi flares.
    I like them a lot mate, hold the shape perfect but only because of the wire insert. Without the insert they would be very floppy but you can shape it easily with the wire.
    http://www.bushranger.com.au/flexy_f...p#.VUFNRZPhBl0
  16. The Following User Says Thank You to AB For This Useful Post:
    Parksy (30th April 2015)
  17. #10
    WA Wheatbelt
    23 Post(s)
    Great thread.
    I'm in the same predicament, too. lol. A bit more work than split rims, but well worth it.
    I bought a roll of ORE, 'Flexi Flares Pack' in 65mm width. It came in a 3 metre length, fixing screws and spring steel wire inserts. I just need the time to work it out and fit them.
    Thanks for the advice about how to fit them.
  18. The Following User Says Thank You to DX grunt For This Useful Post:
    AB (30th April 2015)
