Results 1 to 6 of 6
Thread: Winch Grease
    Whyalla SA
    Winch Grease
    I am bout to add some grease to my new winch.
    ref : http://www.nissanpatrol.com.au/forum...780#post640780
    Is this OK to use: LubriMatic Marine Grease.
    I don't know what is in there besides the original being red in colour.
    Is mixing grease ideal or not an issue.
    Is be inclined to clean out the other grease and not mix them. Id have thought the marine grease was fine.
    Whyalla SA
    You really mean strip it down, clean out grease an repack it
    can you get a fair bit out by hand so to speak.
    Is that marine grease a hi-temp type
    Whyalla SA
    All I can get is this:
    "water-insoluble formula and corrosion inhibitors, making it perfect for use with marine-related applications. It offers superior corrosion protection in severe operating conditions and is ideal for use with winches, hinges, wheel bearings, and in many other uses."
    At present that will do till I take it down again in 12 months time.
    Should say till Jan/Fb when I have some more time.
  7. The Following User Says Thank You to outback For This Useful Post:
    threedogs (31st October 2015)
    Whyalla SA
    There is a very thin rubber seal between the gearbox and main body. What is the best goo to use to improve the seal?
