Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Daylight running lights
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys , I did the Super bright white park lights at front as pic shows , haven't been pulled over by police and lights work great in the daylight regards Alex
    Quote Originally Posted by altech View Post
    I have 68 SMD T20 leds in the park like you haver done, looks affective.
    ET put a stop to my other idea, so might just put indicators up top
  4. #13
    Pffft... don't let me stop ya matey, I got lights everywhere on my rack.
    240 watt Light Bar, Brake and Turn Repeaters, 4 X 27 Watt LED work lights, 24 Watt Tray light and a lit Safety Flag
  5. #14
    Thanks I cant see how making my patrol more visable is wrong.
    But Ill stick to the plan if they are too bright I'll face them up a bit, lol\
    Then again the rear dummy lights are illegal to I think, plan is to get
    it up and on sometime this week end, need some 6 footers about 4
    by tomorrow
  6. #15
    Oct 2015
    Melbourne, Aust
    I know the thread is 1yr old, but thanks 4bye4 for the details and instructions, I wired mine virtually identically.
    I used these 4x of these @ ~$1.50ea: https://www.aliexpress.com/item/1Pcs...336903286.html
    The aluminum backing allows them to be bent slightly so they're curved to the shape of the headlights and sit under the headlight protectors.
    While the Ebay vendor sent me a NO rather than NC relay, the DRL's are wired pin 87A and works fine (until they send me the dedicated NC relays).
  7. The Following User Says Thank You to K_Wolf For This Useful Post:
    4bye4 (16th November 2016)
  8. #16
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by K_Wolf View Post
    All they used instead of driving lights?
  9. #17
    Oct 2015
    Melbourne, Aust
    4x ~$1.50 of the lights, a relay and some wire, they appear to be as bright as those on most other cars.
  10. #18
    Aug 2010
    17 Post(s)
    Wouldn't doubt that at all, but do doubt the legality of using them as driving lights though
  11. #19
    Oct 2015
    Melbourne, Aust
    I have no way to measure if they are "more than 400 and less than 800 Cd" but they conform to the other legalities mentioned on the previous page.
    They appear to be about the same brightness as what is seen on many newer Euro cars, in daylight they draw attention without dazzle, which is what they're intended to do.
