Results 1 to 3 of 3
Thread: 03 gu TD manual nissan patrol 3" lift problems
    Apr 2015
    G'day,
    I recently bought and installed a 3" lift for my 03 gu patrol, I put the shocks and springs in myself and I took the car to the mechanic to put the castor bushings in, the front adjustable panhard rod in aswell I recently took the car to get the wheels aligned because it was shaking and pulling to the right pretty badly, I was told they had no adjustment to realign the wheels and they couldn't do it?
    Does any body know what the problem is and how I can fix it?
    Cheers kgoulds
    192 Post(s)
    Hi mate, did you put in a rear adjustable Panhard as well? If not front and back won't be tracking together and might cause problems. There's not a huge amount of adjustment you can make with the front end once castor is set just toe in and wheel balance. Did the shop give anything else away as to what could be an issue?
    Apr 2015
    Ok cheers no I've only got the front in right now the back one is on order hopefully that will fix my problem
    Cheers buddy
