16th April 2015, 12:24 PM
Getting a drive train clunk when turning.
G'day, all.
Recently when I do a right turn at an intersection (sealed road in 2H), there seams to be some slackness in the drive train which gets taken up as I accelerate. It doesn't do it when making a left turn. Any ideas where to start looking for the cause? The engine and gear box mounts are ok.
16th April 2015 12:24 PM
16th April 2015, 01:28 PM
You sure its in the drive train? Not just the springs shifting. If the rubber sests are worn or gone you will get clunks when turning.
16th April 2015, 04:37 PM
Check the radius arm bolts. This is what mine did.
Check them asap as its easier to tighten them have to weld on washers
16th April 2015, 04:48 PM
Apprentices Rule!!!
Yep, check all your bushes. And if one is stuffed, replace all in that category as the rest probably aren't too far begind.
(Yes i made that mistake myself)
The Following User Says Thank You to Punderhead For This Useful Post:
16th April 2015, 05:33 PM
It feels as if there is a tiny lack of power then a quick boot from behind.
16th April 2015, 05:49 PM
Mine sometimes feels like that from a bit of play in the seat slider
The Following User Says Thank You to Figjam For This Useful Post:
16th April 2015, 05:52 PM
I dealt with all the seat slides within a month of getting the vehicle.
16th April 2015, 05:56 PM
Put handbrake on and get somebody to rock car back and forth, if you see rear trailing arms move around bushes stuffed. I also get similar when coasting downhill with cruise control on, car sort of hunts a bit trying to keep constant speed.
The Following 2 Users Say Thank You to liftlid For This Useful Post:
Bloodyaussie (16th April 2015), mudnut (16th April 2015)
16th April 2015, 07:25 PM
All arm bolts have been checked tight, all the bushes look ok when levered with a crow bar. I will get someone to rock the car and have a look.
The rear diff oil is due to be changed out. Could that cause the diff to grab?
17th April 2015, 10:00 AM
mudnut
All arm bolts have been checked tight, all the bushes look ok when levered with a crow bar. I will get someone to rock the car and have a look. The rear diff oil is due to be changed out. Could that cause the diff to grab?
Anything grabbing inside a diff is usually fairly violent.
The Following User Says Thank You to liftlid For This Useful Post:
