Results 21 to 30 of 48
Thread: Usb charger to fit rocker switch slot
    Expert skiman's Avatar
    Apr 2015
    Fern Bay NSW
    I've been looking into something similar. Keep in mind that most of the USB chargers ive seen on ebay and at Jaycar have a 1.0A and a 2.1A slot (or they might advertise 3.1A shared across two slots). Such a config wont charge 2 ipads. Ipads need a 2.1A slot. Even if you want a faster charge on your mobile, chose the 2.1A slot.
    So if you're thinking of throwing a couple of these USB sockets in the back seat for the kids, make sure you get 2x 2.1A... otherwise.. "are we there yet?" ... "are we there yet?"
    Im looking for something like this in a dashmount config - http://www.jaycar.com.au/Power-Produ...arger/p/MP3666 May be able to pull the guts out of it and refit it to one of these http://www.ebay.com/itm/Car-2-1A-Dua...3D131492692357
  2. The Following User Says Thank You to skiman For This Useful Post:
    katwoman (5th May 2015)
    Posted these up for you in one if your other threads a while back Kallen
    Main cigarette lighter socket replaced with dual usb
    Accessories socket added here
    And another added here
    And just use a usb adaptor plug for the accessories sockets if needed
  5. The Following User Says Thank You to Clunk For This Useful Post:
    BigRAWesty (5th May 2015)
  6. #23
    43 Post(s)
    Posted these up for you in one if your other threads a while back Kallen Main cigarette lighter socket replaced with dual usb <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=57788"/> Accessories socket added here <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=57789"/> And another added here <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=57790"/> And just use a usb adaptor plug for the accessories sockets if needed
    Must have missed it.
    How did you go about fixing it in?
    I didnt, was already done by the previous owner lol
  8. The Following User Says Thank You to Clunk For This Useful Post:
  9. #25
    Expert bishbashbosh's Avatar
    Nov 2014
    can you just run wire from your aux battery to the location and wire up?
    i pulled my cigi lighter out the front and tried to wire it up but the wires in place did not want to play ball for some reason!
  10. #26
    Thats all I did , just tapped into the power cable going to the rear power outlet.
    Don't forget to fuse it at the battery end, I used these
    http://www.ebay.com.au/itm/261879292...%3AMEBIDX%3AIT
  11. The Following User Says Thank You to threedogs For This Useful Post:
    bishbashbosh (11th May 2015)
  12. #27
    Nov 2014
    i got a baintech one with dual usb plugs..
    so run some regular cable and fuse direct from aux battery.. what size cable and fuse you think?
  13. #28
  14. The Following User Says Thank You to threedogs For This Useful Post:
  15. #29
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I find it easier to run a thick cable to a fuse block that is fused at the battery.
    I'm a big fan of blue sea fuse blocks like this one
    Find a spot for it under the dash, passenger kick panel, glove box etc and then you can run as many fused accessories as the fuse block has spots
    Lucus30's 1999 GU ST TB45E
  16. The Following User Says Thank You to lucus30 For This Useful Post:
  17. #30
    Nov 2014
    thanks guys.. will look into the fuse box also as that means i just run lines from the box which is nice a clean coz i aint got a clue whats going on behind the dash with the cabling and that way i know whats what!
