11th April 2015, 11:46 AM
Mechanical help needed thanks!
So I'm not very mechanically minded, but I wanna learn and teach myself to save some $$ I need to change the belts on my GQ 2.8l but not sure how anyone got any advice or can point me in the direction of DIY explanation videos or books that have step by steps instructions any help greatly appreciated thanks in advanced
- Paul
11th April 2015 11:46 AM
11th April 2015, 12:28 PM
type in your request in the search engine ,top right
there is oodles of info there for you in there good luck
13th September 2015, 09:25 AM
Hi Mate,
I have done it on mine. But I have a different engine than you. Mine is TB42 carby. Changing belt will be almost same I guess for Fan - water pump, Alternator, A/C, Power steering. Here are some general tips.
Buy all belts which you gonna replace. Coz there is a sequence to remove belts and put them back in.
For safety remove Battery (-) terminal first. So no one can crank the engine.
Then loose the tension adjuster bolts or pulleys. loose them to maximum. So it will be easy when you put new belts which are very tight.
Remove the most forward belt. then second belt..
when installing belts, last out- first in order.
Adjust tension of belts to manufactures specs by tightening adjusters. Torque other related nuts and bolts.
remove all tools. check again for correct installation.
Connect battery negative (-).
Ready to start engine. And its better to check belt tension again after some run.
Most of the time its worth knowing mechanical jobs, how to perform.
Good luck
The Following User Says Thank You to Fox7 For This Useful Post:
MudRunnerTD (13th September 2015)
