Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: $15000.00 to spend what would you do?
    Mar 2015
    Central Coast NSW
    Ok so if you had 15k to buy and build a touring 4wd what would you buy? what would you do?
    GQ TD 4.2 with 2" lift and 285 tyres, awning and cargo barrier
    and travel as light as you can, will leave plenty of change for
    long range tanks and a winch if you think you'll need it
  4. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Gecko17 (10th April 2015), Lumbnuts (10th April 2015)
  5. #3
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    A tidy td42 gq turbo with 3"lift and 33's..
    Winch bar and winch.
    Draw system
    Air on board system
    Roof rack
    Uhf and hf radios
    Long range sub tank.
    That should see fit to the 15g
  6. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
  7. #4
    Patrol Freak Gecko17's Avatar
    Mar 2013
    What they said...
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
  8. #5
    Patrol Freak
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    HF radio? Are you sure that is of real value for a startup? Definitely something to consider for remote stuff.
    Otherwise I agree, a good clean GQ 4.2 diesel, with bar, rack and a 2" lift with 285's. You may find a good one without a turbo, and it is always something you could add later.
    UHF radio;
    Air compressor - I find the air compressor is the single most used bit of kit I have, so definitely include a good one when you are putting together your recovery gear.
    A long range tank is a good addition and;
    Spotties if you intend on covering the miles at night.
    If you have any change, put it into your suspension and brakes right from the start, unless it has already been done. Otherwise, start collecting spare bits and pieces like radiator hoses, fan belts, tools etc.
  9. The Following User Says Thank You to FNQGU For This Useful Post:
  10. #6
    Ballarat, Vic
    174 Post(s)
    Quote Originally Posted by biggqwesty View Post
    For touring? Why?
    What sort of fit out depends very much on both where you want to go, (blacktop with occasional off road excursions, long but reasonably well travelled dirt roads or tracks where you may not see another vehicle for days at a time), your travelling style (eg, moving on most days vs staying put for a week or two at a time), how long you want to go for, how long you want to be able to stay bush between re-supplies & what level of comfort you are seeking, travelling alone or with other vehicles, how many in your vehicle etc etc.
    It’s hard to know if you haven’t previously travelled much but nevertheless it important to nut it out before you start fitting a vehicle out, or it’s easy to waste the resources you have
    If you can say more about those things you will get answers from others which best suit your needs.
    Different folk have different priorities so what suits one won’t suit another.
    Other things not yet mentioned which I consider essential (for the way in which we travel) are:
    An awning/rain & sun shade
    An electrical system to run a fridge/freezer without need to regularly visit caravan parks
    Sufficient water & food storage
    A set up which is quick & easy enough to prevent it becoming a chore if moving on most days.
    Recovery gear including a winch (because we intend travelling alone in remote areas).
    Generally lp gas stoves are the simplest as an alternative to the camp fire, although there are a few alternatives.
    Hot water - just go to a caravan park for a shower every few days, have a swim or have other means of heating water
    Sleeping accommodation can be, a mattress under a tarp, swag, ground tent, rooftop tent, camper trailer or caravan.
    Consider your toilet needs. Wives & girlfriends often prefer greater comfort/privacy. Don’t add to the crap that others leave - consider a portapotti or similar.
    Around Australia servos can generally be found every 300kms or so unless going more remote & then the long range tanks become highly desirable, but for the routes that 95% of travellers take they are not needed.
    In remote areas emergency communication is important. Minimum should be an epirb. After that you have the choice between UHF (CB) & HF radios, mobile phones, satellite phones & a few gadgets which combine communications & tracking. A Telstra mobile phone will give you the best phone coverage. Much of the main highways are covered & anywhere within 25kms of a town or a mine generally.
    There really is an infinite way of setting up for touring & many more things to consider. It may feel overwhelming at the beginnng but it really is worthwhile working out what will suit you before starting a fit out. Avoid the temptation to buy *everything* just in case . .... doing that is expensive & heavy & I can guarantee that those who do find that they don’t use half the stuff they’ve lugged all round the country.
    Check out as many other set ups as you can first. Go camping with the bare minimum & suss out what is important to you. Whatever you end up with will be a compromise between many things.
    A Nomadic Life (Blog)
  11. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    DX grunt (10th April 2015), Lumbnuts (10th April 2015)
  12. #7
    For touring? Why?.
    I'm sure you agree that suspension should be upgraded from standard for any real touring, a small lift is even better than stock!
    Bigger tyres are better for a number of reasons, the larger width is the most important thing for touring I would say.
  13. #8
    22 Post(s)
    15k wouldn't be enough, that would only cover a GQ td42 suspension, tyres, basic engine mods with nothing left over for touring mods and accessories
    96 GQ coil/Cab
    08 G6eT
  14. #9
    You could get an awesome TD42 GQ with tyres and suspension pretty well setup for 10k,with 5k leftover for whatever else needs to be spent.
  15. #10
    $15k was the limit thats why I was wondering if the expense of a winch was neccessary.
    But I would probably add a 80watt panel to compliment a dual battery system. As we all know you can spend $$$$$$ and still not be finished.
    But $15 grand would be a budget tourer, Ive seen backpackers buy an old Tojo for $1000 do a lap and sell or take it to the tip when finished.
    So recapping as some went over budget, long range tanks a must IMO. Awning not expensive but great for keeping out of the outback sun.
    Totally agree on the compressor plenty of uses when touring for sure, A decent ice box reason being I'd go over budget buying an Engel or similar . As Im travelling I need fuel every other day so ICE is no problem, and if I have water issues [radiator] I have plenty of water to top up. You cant do that with an engel.
    Wont need driving lights as night driving outback is a no no. 285s as that size is every where even if stuck you can throw on a 7,50 x 16.
    Think that makes a decent tourer depending on the value on the Patrol, Im hoping the Patrol will alreaady have a bull bar.
    EDIT and a decent window tint
  16. The Following User Says Thank You to threedogs For This Useful Post:
