Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: TB42E front brake calipers
    Apr 2014
    Its all supply and demand.. I have seen the calipers for from $150-450 a set.
    They seem to get snapped up pretty quickly. Make sure you get the bolts with them and you will need new rotors and pads. I would also put a seal kit through them as well as you just don't know what condition they are actually in on the inside. I have seen calipers that looked OK on the outside, but once you pull them apart its a different story.
    When I did the upgrade, I pulled mine apart and there was quite a bit of gunk in them, but luckily the pistons were fine and all went back together with new seals perfectly.
    Yeah I'll definitely be doing a seal kit when I find some. Thanks for that though.
    You're not wrong about them getting snapped up quickly, saw somebody wrecking one on facebook last night, I got in within 5 minutes of being posted and he said somebody had already claimed them.
  4. #13
    Do the twin piston calipers from a GU fit the GQ?
    http://pages.ebay.com/link/?nav=item...066800&alt=web
  5. #14
    Im going down to a 4x4 shop very soon to talk about my intake I'll
    ask about some 2 pot calipers while I'm there for you.
    He does a lot of mods and mainly only Patrols.
  6. #15
    Thanks John. Patrolapart have a 2nd hand set for $450 but that's a bit more than I want to spend at a moment
  7. #16
    If Andrew has some it wont be that high, fingers crossed though
  8. The Following User Says Thank You to threedogs For This Useful Post:
    Winnie (10th April 2015)
  9. #17
    Thanks mate that'd be great
  10. #18
    Are you doing all four or just the front???
    Sorry for delay mate just dropped off some fire wood
  11. #19
    Just the front mate as the rears are the same. Only after 2nd hand and I will be rebuilding them regardless so they don't need to be in great condition
  12. #20
    Apr 2014
    Pretty sure they won't fit mate
