Results 1 to 5 of 5
Thread: backfireing
    Apr 2015
    backfireing
    Hello all I have an rb30 and it keeps back firing under load
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Back firing on a non-modified Rb30 can be caused by the following factors:
    A faulty Exhaust Gas Recirculation (EGR) system.
    Incorrect Timing.
    Thermostatic air cleaner system.
    Vacuum leak.
    Damaged valve spring or sticking valve.
    Intake air leak.
    Carby float level incorrect.
    Cracked distributor cap.
    Faulty distributor rotor.
    Tracking between contacts in the distributor cap.
    Faulty high tension leads.
    Faulty spark plugs.
    Leaking exhaust manifold gasket or manifold to engine pipe gasket.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Incorrect Timing.
    Vacuum leak.
    Intake air leak.
    Faulty spark plugs.
    If it's only under load I'd be starting with the vacuum advance.
    Patrol Guru
    Jul 2014
    6 Post(s)
    I had some recent 'backfiring' on my rb30. Turned out it was backfiring through the intake, ended up being old ignition leads arcing out and sparking at the wrong time. Changed plugs while I was there and she runs like a dream.
  6. #5
    Id be looking at electrics ,like Dizzy or leads failing
