Results 1 to 9 of 9
Thread: 80-90 or 85-140 limslip oil for rear diff.
    Advanced
    Hi all
    I'm about to change the rear diff oil in my patrol (2007 CRD). Reading through previous posts most people are saying to use 85-140 grade. The owners manual says to use 80-90 grade. I also checked the penrite website and it suggests also to use 80-90 grade.
    From my understanding (and correct me I'd I am wrong), 85-140 is thicker and more suited for warmer climates. Therefore it should be better to use here in Australia.
    So my question is it ok to use 85-140 for my patrol or should I stick with what the owners handbook suggests?
    Thanks in advance
    NEV
    Legendary Alitis007's Avatar
    15 Post(s)
    The 80/90 is for open diffs like the front and for the ones with the factory vacuum locker or aftermarket lockers and is generally a mineral oil. The lim slip takes 85-140 in all my books (workshop bible, penrite lubricant guid, etc) keep in mind tho penrite have 2 types of 85-140, 1 with the friction modifier mixed in the other separate.
    Patrol Freak kevin07's Avatar
    georges hall
    yep i was told the limslip 85 - 140 here as well
    07 crd,,bridgestone 697lt, 2.75 buedesert ex, SOLD theres a lot of my blood, sweat and money in that troll.
    92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar SOLD with a heavy heart but gone to a nice young fella
    13 y62 the beast that burbles
    Expert billyj's Avatar
    gordon
    3 Post(s)
    if you can find it penrite do a straight 140 diff oil, works a treat with the big nissan lsd
  6. #5
    May 2012
    aren't LSD oils different from standard gear oils?
  7. #6
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by raider_td5 View Post
    Yup correct see Altis' post above he's in the money
  8. #7
    Mar 2016
    Hi Nev what did you end up going with? My book also says to use 80W90 LSD oil in the rear (08 CRD), as does the caltex product finder webpage. But every one seems to recommend the 85/140. Confused.
  9. #8
    Aug 2011
    River Heads Q
    4 Post(s)
    Up to 2006 rear with LSD SAE140API with 10% friction modifier or 80W-90API GL5 for diff locks
    Post 2006 Nissan hypiod LSD 80W-90 GL5 or equivalent and as above for diff locks
    Edit-- This is from Haynes workshop manual and for my 2006 ute from the Nissan owners handbook
    At the end of the day, all you have is yourself and all you need is your friends (and in our case our Patrol)
    2006 GUI1 4.2TDi Coil Cab "almost" standard
  10. #9
    The master farter
    mudski's Avatar
    462 Post(s)
    Quote Originally Posted by Nuggetx1 View Post
    If your book recommends it, then use it. I reckon. Atleast you have whats recommended in it then.
  11. The Following User Says Thank You to mudski For This Useful Post:
    Nuggetx1 (5th September 2016)
