Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Speedo Issues
    Advanced Mudboss's Avatar
    Nov 2011
    Port Augusta West South Australia
    Speedo Issues
    Hi All
    Just put 35" tyres on my GU TD42, and like expected the speedo is 10km behind my road speed. I live in SA and am trying to get the tyres engineered so the speedo must read right. I cant affort dif gears yet but what have people dont to correct your speedo.
    Also im legalising the 4" lift, any information on little thing to look out for?. Got the engineer orginised.
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    If your actual speed is still behind then your right.
    You can have up to 10% behind but 0% in front.
    But I guess that's just a mix up and your doing 110 when gauge says 100..
    So 2 things you can do. Buy a replacement gear for the box so the output is changed.
    Of swap diffs to a higher ratio.
    THe closer to stick ratios you can get the better the car will perform and the closer your speedo will be.
    Mine on 33's is spot on $ for $.. So if your running 4.1 diffs you may up to 4.3 ratio.
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    And also good luck with the lift. That'll be the hard bit. A lot involved with it here in Sa.
    You may find you'll need to upgrade the brakes to going 35's.
    I did have the blokes name who does it all but is on my old phone. (Gone).
    I was investigating an a 3rd anchor point in the middle row
    W.A. (wandering aust)
    Unless you are already on the highest number of teeth you can purchase from Mr Nissan or Wreckers the correct speedo drive cog and swap that out.
    Very simple job
    They make about 4 different size cogs each with an extra tooth over the previous.
    32743-VB015 15 Teeth
    32743-VB016 16 Teeth
    32743-74P17 17 Teeth
    32743-74P18 18 Teeth
  6. #5
    Dress to the right lol
  7. #6
    Nov 2011
    Thanks fellas. i didnt know if i could just replace the speedo cog or not.Thanks for the part number, will the part number be written on the cog at all or i just count the teeth.
    The engineer that im going throught is pretty posotive with the lift. he says hes dont heaps of patrols with gmv upgrades that usualy lift the car 4".will let you all know how i go.
  8. #7
    Nov 2011
    um ok, next question. do i go up a size or down to increese the speedo reading
  9. #8
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    On a gq you can adjust the speed shown at the cluster , not sure if the gu cluster has the pot though.
  10. #9
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by Mudboss View Post
    Great question. If your replacing the gear which drives the output then down a tooth.
    If your replacing the output sprocket itself then up a tooth.
    I think that's right. Have never done it so only working on ratio changes.
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Thanks fellas. i didnt know if i could just replace the speedo cog or not.Thanks for the part number, will the part number be written on the cog at all or i just count the teeth. The engineer that im going throught is pretty posotive with the lift. he says hes dont heaps of patrols with gmv upgrades that usualy lift the car 4".will let you all know how i go.
    What's this blokes name and number?? See if it's the same bloke.
