Results 11 to 20 of 22
Thread: UHF problem discovered - but what to do?
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    I very rarely use cds/dvds anymore. All my music is on a small stick but a rear mounted one on a lead would be better because ive lost count how many times ive almost snapped the little stick when going to change gears.
    .......... TPC's Avatar
    63 Post(s)
    It would be very unlikely you would buy another stereo with the same problem, it is not common for them to cause interference like this.
    I have a rear usb socket with ext lead to centre console and as others have said it is a better way to have it.
  4. #13
    W.A. (wandering aust)
    Agree with TPC, very unusual problem to encounter these days and 99.9% must be an internal fault in that specific head unit.
    I have only used Chinnee Head Units for 10 years or so now and they have all been quite reasonable performers.
    In the name brands Alpine seem to have hit a good price point versus features but I think you could purchase whatever caught your eye without any issues
  5. #14
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Humour me,Cuppa, and wrap all of the unit and its cables in alfoil, (without shorting out anything). Turn it on for a short time and see if the problem disappears.
  6. #15
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Earth the alfoil??
  7. #16
    SW Vic.
    80 Post(s)
    Yeah. And put some slits near the top and bottom to let air circulate. I just want to see if it is feeding a high frequency back into the loom.
  8. #17
    ... as soon as you slit the Alfoil it negates the Faraday effect.
    If you think it is the loom that is radiating (which it certainly could be) you have to wrap and earth the loom.
    Wrapping the device will have no effect on the loom which will still be free to act as an antenna
  9. The Following User Says Thank You to the evil twin For This Useful Post:
    mudnut (29th March 2015)
  10. #18
    Expert Kelvinator's Avatar
    Aug 2011
    maryborough and gladstone queensland
    Build a faraday's cage around your whole car. then sit on the roof and use your uhf
    Flip er on er wheels, she'll run!
    4.2 Diesel GQ 4" King'n'ProComp Lift, 33's, Gu steer box conversion, custom drawers and a heavy right foot. Turbo kit, quarter chop and a heap of barwork coming very soon!
    A BIG thanks to Johnny at Repco Northside Rocky for always sourcing me the gear and parts I need ASAP You've saved me many times.
  11. #19
    Ballarat, Vic
    174 Post(s)
    It may be a little while before I try accessing the unit to earth it (or wrap it) as other things are taking precedence. Having removed the rooftop tent I’m currently in the middle of splitting up my portable solar panels (5 x 60w) & mounting them to the roof. It’s a job which is taking far more time than I’d considered it would. Using only Sikaflex 11fc to glue the mounts to the roof (rather than Sika’s far more expensive & harder to work with 252) has meant painstakingly taking off paint so I can glue direct to aluminium to achieve the strongest bond. The panels themselves are bolted to the mounts using riv nuts. (Believe me I’ve just about had enough of working on my knees up on top of the pod!). However I’ll certainly follow up on suggestions at some point, & report back. For the time being if I go out & need to use the CB if out 4wd’ing with others, pulling the radio fuse will suffice, but in the long term it’s a solution which wouldn’t work for long distance travel/communicating with other travellers, truckies etc.
    A Nomadic Life (Blog)
  12. #20
    Aug 2014
    Kingsley WA
    15 Post(s)
    Maybe put an inline switch to save having to pull the fuse every time. Only as a temp measure I mean.
