Results 1 to 3 of 3
Thread: Auto transmission fluid change on GU Patrol question.
    Oct 2014
    Newcastle
    Hi fellas,
    I am in the process of changing fluids on my 2008 GU Auto Patrol with 101,000 km on the clock.
    The manual says that the auto contains 11.8 L of ATF. On draining the transmission at the sump only 4.2 L came out, so I guess the rest is in the oil cooler and pipes How do I go about draining the extra oil in these areas? I am refilling with Penrite Full Synthetic ATF FS.
    Michael
    2008 GU DX Auto, dual batteries, Safari snorkel, Warn winch. Engine standard CRD 3L
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    You can't drain it, you need to flush it. The process wastes a bit of oil but you get the whole system flushed including cooler and lines. Highly recommended if your changing to synthetic.
    Your local trans shop could do it.
    John
  4. The Following User Says Thank You to jff45 For This Useful Post:
    micknor51 (28th March 2015)
    Patrol Freak kevin07's Avatar
    georges hall
    absolutely get it all flushed out if your going synthetic I put penrite semi mhp, I took the pan off changed the filter and used compressor up the cooler pipe and got 8 litres out. (measured it) put 8 back in and from there change the oil out of the pan every 10 thousand. and your oil will always be fresh.
    13 y62 the beast that burbles
  6. The Following User Says Thank You to kevin07 For This Useful Post:
