Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 100
Thread: Off road driving technique
  1. #81
    Oct 2011
    Essendon
    Sent from my iPhone using Forum Runner
  2. The Following User Says Thank You to Drewboyaus For This Useful Post:
    Clunk (24th March 2015)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by TroutNut View Post
    "hand throttle was NOT designed to get you to "gain forward momentum up massive inclines"
    it was designed to give you the ability to use the throttle WITHOUT using your feet - ever heard of the old Capstan Winch - or a PTO........??? you use a hand throttle for those"
    Its called a hand throttle because it's a hand throttle. We all know you don't need your feet to use it. Anytime a winch is used, an operator needs to be in the vehicle to maintain control if something snaps or otherwise goes wrong, otherwise the car goes on its own way uncontrolled. The procedure for that is simply open the bonnet to shield the person in the drivers seat from a snapped cable.
    "looking at situations where you're stuck stationary on dangerous slopes when you need the grip of four calipers on the disc/drums.
    mate, if your in THIS situation, you have OTHER things to worry about - like just HOW did you get in this predicament......"
    If you're stuck in said situation, what you need to know is how to get out of it.
    You sound like someone who'll end up injuring somebody else, if natural selection doesn't take its course first.
    thanks for your Vote of confidence in me
    better hope I'm not the only person around when you stall half way up a hill mate - which it sounds like you do quite frequently
  5. The Following User Says Thank You to Bigcol For This Useful Post:
    Winnie (24th March 2015)
  6. #83
    NT
    Gentlemen...
    Take a step back... Dismount the moral high horse...
    We're here to learn stuff, pass on hard earned knowledge. It looses it's effectiveness when buried in a slinging match.
    I was enjoying this thread.
  7. The Following 7 Users Say Thank You to P4trol For This Useful Post:
    Avo (25th March 2015), Bob (25th March 2015), cgm (24th March 2015), happygu (24th March 2015), krbrooking (24th March 2015), threedogs (25th March 2015), TPC (25th March 2015)
  8. #84
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    as there is so many different types of 4wd's now
    same as so many different people driving them
    what works for 1, may or may not work for another
    I will apologize to Troutnut, as obviously he has only ever done a particular course run by some famous dude......
    I did 2 with the Australian Army in 1970 (in New Guinea)& 1978 (Midland Base Workshops), in Land Rovers - so what was applicable then, is way way way out of date now
    especially as we dont have Jungle in West Aust, nore do I drive a Land Rover
    I have also learnt that you are NEVER to old to learn something new - with regards to 4wd's, driving situations etal
  9. The Following 4 Users Say Thank You to Bigcol For This Useful Post:
    cgm (24th March 2015), Drewboyaus (24th March 2015), katwoman (25th March 2015), Maxhead (24th March 2015)
  10. #85
    Oct 2011
    Essendon
    Quote Originally Posted by Bigcol View Post
    as there is so many different types of 4wd's now same as so many different people driving them what works for 1, may or may not work for another I will apologize to Troutnut, as obviously he has only ever done a particular course run by some famous dude...... I did 2 with the Australian Army in 1970 (in New Guinea)& 1978 (Midland Base Workshops), in Land Rovers - so what was applicable then, is way way way out of date now especially as we dont have Jungle in West Aust, nore do I drive a Land Rover I have also learnt that you are NEVER to old to learn something new - with regards to 4wd's, driving situations etal
    Did that course involve learning to change Landrover axles? Recovery techniques using a Nissan Patrol? LOL
  11. #86
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    nah, the old series IIa was / is far better than the later ones........
    had to be recovered twice in Patrols - both times sand was like talcum powder
    probably 1/2 doz times when I used to drive Cruisers, and always in freaking MUD..............
  12. #87
    So windows up or down?
  13. The Following 5 Users Say Thank You to Clunk For This Useful Post:
    BigRAWesty (25th March 2015), Drewboyaus (24th March 2015), gaddy (24th March 2015), happygu (24th March 2015), Punderhead (25th March 2015)
  14. #88
    Patrol Freak gaddy's Avatar
    redlands
    Just disconnect the battery for 30.15 min and the hill will disappear
  15. The Following User Says Thank You to gaddy For This Useful Post:
  16. #89
    Oct 2011
    Essendon
    And make sure you clean the MAF.....
  17. The Following User Says Thank You to Drewboyaus For This Useful Post:
  18. #90
    80 Post(s)
    I have learned one thing from this thread : a patrol accelerator is sponge-worthy. I will try using a sponge under the pedal next time I encounter some rough stuff.
  19. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    Bigcol (24th March 2015), cgm (25th March 2015), threedogs (25th March 2015)
