Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: ZD30 Lift Pump Mod
  1. #21
    462 Post(s)
    Quote Originally Posted by 05Y61 View Post
    One more thing. I'm also installing a second filter should I put this filter first or after the factory filter?
    Depending on what micron the second filter is. The main filter will be around 8 micron, brand depending. So if your new filter has finer filtration ability, i.e 8 micron or less, it will need to be after the main filter, to catch what the main filter is unable too, if its like a 15 or 30 micron, before the main filter, to catch the larger particles to assist the main, finer, filter.
    BrazilianY60 (14th October 2021)
    Apr 2021
    Brazil
    Makes sense. Otherwise you would quickly clog the first (finer) filter and have a big restriction. Thanks for the explanation.
