"The fuel pump is just wired from ignition so pump will work all the time."
I've been looking into this and doing some homework. So when you say it's working "all" the time, I'm assuming this cuts out once it reaches max pressure build-up ? Even if ignition is on, but car not running ?
So in a nutshell, these have a cut-out pressure switch or something built-in ?
