Results 1 to 6 of 6
Thread: Zd30 2008 crd boost gauge fit up
    Advanced
    Mar 2015
    Boyne Island
    Hi all this is the pipe running from the turbo to the inter cooler is this where I put the nipple ( indicated by my finger ) to atach my hose for the boost gauge if not where and could you add photos please.
    Remember laughter is the best medicine. If you don't laugh you die.
    you could silver solder the bung there if you like,
    You can also buy boost gauge adaptors that fit uo under your boost sensor
    http://www.ebay.com.au/itm/Quick-Fit...item541a9416ca
    The master farter
    mudski's Avatar
    461 Post(s)
    On any of those pipes mate will be fine. Where ever is easiest for you would work.
    W.A. (wandering aust)
    I wouldn't fit one there.
    I would recommend fitting the sensor post intercooler not post turbo.
    That is the pressure the ECU and the engine will see.
    With a 2008 CRD I wouldn't even bother with a boost gauge at all and use a Scangauge
  6. #5
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Alternatively, you could just plug a scangauge into your ODB port and get your boost reading from the sensor already there
    ________________________
    ______ 2017 D-Max _______
  7. #6
    Advanced
    Mar 2015
    Boyne Island
    Would you recommend running egt gauge with this system. Also which unit would you recommend Scangauge2 or the ScangaugeE cheers Nisshead
