Page 9 of 9 FirstFirst ... 789
Results 81 to 89 of 89
Thread: Air box mods
  1. #81
    Then he's gonna make one for me.
    I dont have funds for multiple Dyno runs, wish I did.
    I will also be changing the rear IC pipe which I think is less than 55mm
    and enlarges to 60mm, more air in plus Ill be using gold tape on some pipes to try to keep the heat down.
    FYI my DP chip is set on 5 atm, max boost is about 20psi, we will see eh.
    will look better when its tigged and all tightened up.
    braided hose is cheap enough these days this is AN10
    the hose ends will be black when all is finished
    braided hose goes to the catch can
  4. #83
    All tigged ready to fit,
    will fit it up over the week end.
    The 60mm pipe to the intercooler will remain the same
    diam. no point increasing it .
  5. #84
    What time you want me over so you can fit it up on my car mate?
    threedogs (1st May 2015)
  7. #85
    From what I gather of the outlet of Turbo for boost is 48mm to 60mm at the IC
    some how I'll change the piping to allow more air in, but that may lower boost levels
    will need to consult on that one
  8. #86
    Is it on yet John?
  9. #87
    Not yet Mark waiting on some AN10 hose end fittings to arrive, I'll do it either at On Track or TJM Airport West.
    In case I need something.
    My Gold heat reflective tape arrived I'll be taping the IC tanks and the pipe going to the IC,
    hoping to lower in coming air temp a bit. Could use gold leaf but might look too decadent lol
    Hopefully the clamps will arrive tomorrow they are about due.
    Loving the reflective gold tape, hoping it works as its not cheap
  10. #88
    My AN 10 hose fittings have arrived for the catch can hoses.[braided AN10]
    chances are I'll fit it up tomorrow. As luck would have it I will
    be doing a Demo of my Spare Wheel hoist at a 4x4 shop.
    Ah life is good ATM
  11. #89
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    How did you go fitting it TD. did it all go well for you. were the results what you wanted
