Results 1 to 4 of 4
Thread: Diff breathers
    Dec 2016
    Yarrabah
    Post Diff breathers
    Hi Peoples
    I'm looking at getting a set of diff breathers . Do I need to buy 4 or can I get away with just 2 ?
    Tia
    Craig
    193 Post(s)
    Hey mate, not sure on the GU, but on the GQ there's the rear that runs into the chassis, then the front diff, gearbox and transfer case all join together from factory, so yeah can get away with 2. I just got a Roadrunner kit which is a very nice litte kit, has 4 tho, not sure if they do a 2 one . . .
    175 Post(s)
    And don't forget the gear and transfer have steel pipes and you will have to adapt somehow it to the breather tube. This is on the GU anyway .
  5. The Following User Says Thank You to Hodge For This Useful Post:
    Bacho86 (13th September 2017)
    Expert Skitzyrex's Avatar
    Jul 2013
    Quote Originally Posted by FNqGu04 View Post
    Hi Peoples
    Tia
    Craig
    4. At the front you'll have diff, transfer case and transmission. You'll need to run a seperate line for the rear diff.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
